colorado emissions question
Discussion in 'The Garage' started by bettabruce, Feb 7, 2005.
  1. bettabruce
    bettabruce Registered Member
    Feb 7, 2005
    19
    Jackson, MS
    i'm new to CK5 and not real familiar with posting in forums. i own a
    75 K5 and live in jackson, ms. i want to fix up my truck, but i know
    little about the game. i plan to move to colorado in about a year
    and was told that my K5 won't pass emissions there. any info would be
    greatly appreciated. i'm thinking of the colorado springs area.
    thanks much.
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Colorado has one standardized test center, Envirotest. You'll need to bring in your K5 to one of the centers near you. They will do a visual inspection for exhaust/emission components, check your gas cap(s) for vacuum seal and run your vehicle on a dyno with probes in th ex-pipe. There is an idle test and then a run-up to highway speed test. They'll test it twice for each.
    If you fail either test you will have to address it before you can get your license plates. However they will apply the cost of the first test to a re-test within a certain period of time. In CO you have to have a valid emission test and proof of insurance to get your plates.
    Also 82 and older vehicles get tested once a year at 15.00 a pop. Newer vehicles are 25.00 every 2 years.
    I think that covers it, if I missed something somebody else jump in.
  3. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Don't forget that he has an '81 or older vehicle which means that he has to go to an '81 or older test facility. They're normally a bit more relaxed about the rules than envirotest, but same basic things apply.
    Atleast that's how it works in Denver. I'm not sure in Colorado Springs since I haven't gotten a test here yet. Guess I'll have to find out soon, though.
    Also, since you would be able to get special collectors plates (25+ yr old vehicle) there are certain emmissions rules that help you out if you get the plates. Like testing every 5 years instead of every year. And some other stuff I don't know about, too.
  4. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Emmissions
    Here in the Springs there are a bunch of test sites. I use the Jiffy lube down the street from me. They don't have a dyno just a sniffer. They run my Sub thru the rpms and do a visual. Its a 91 so it gets tested every other year.
    Now the diesel is another issue there is only one palce to get emmissioned. They have a dyno and visual inspections, 40 bucks once a year. As long as you are running well I imagine you will pass. I had a 76 Ford F-150 that had headers and I passed every year in Denver and Colorado Springs.
  5. OrangeCrushK10
    Jan 25, 2003
    1,425
    Also, it varies from county to county. Some counties have NO emmisions requirements. Those are the counties that are fairly low populated, though.
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Not to hijack, but where in Jackson are you. I live out near the reservoir on the Rankin side. Oddly enough just around the corner from another CK5'er. Where do you go to wheel?:D
  7. bettabruce
    Feb 7, 2005
    19
    Jackson, MS
    North Jtown
    I live in North Jackson, send me an email at brucemiller76@gmail.com.
    I don't actually do any offroading at the moment, the K5 I bought
    doesn't have working 4 wheel action. I'd be interested in what shops
    you recommend, as well as any other enlightenment that you could
    probably share.
    THANKS TO ALL WHO RESPONDED! I was told by a mechanic friend
    that my truck wouldn't pass emissions, but now I have some hope.
  8. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Just what I was gonna say, register it somewhere other than the front range. No emissions to worry about anywhere over here on the west slope as far as I know.
  9. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    One way around emissions testing is if you own more than two acres of land, and have some sort of livestock(cows, chickens, horses). Then you can license the vehicle as a farm truck and are not required to pass any tests at all! Been working for my 83 k30 for many many years now. They say that there are limits to how often it can be driven to and from the city that issued the plates but I have never seen anyone pulled over for it, besides I guess you could always say you are making a feed run.
  10. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Few comments here.
    For starters, as an 80 or older unti, your will still have to pass emmissions. Once you pass, you can register the vehicle for a five years period. If you choose not to do that, you will need an E test every year.
    When they do the test, they will check to see what type of emmisions stuff you rig came with originally. It will need to have that stuff. That will most likely just be the gas cap & maybe cat converters.
    Just make sure you have a good tune up and hot cat converters before testing. That will make a diff as they work much beter once hot.
    I just got a 79 K10 to pass with the 400 in it.
    Good luck & let us here in Co Springs know if you need any help prior to/and once you arrive:thumb:
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    You don't have to have it tested at an '81 or older place but you may. Also, if you want to get collector's plates (vehicle must be 25+) you have to pass emmissions once, pay 5 years registration ($100 including new collector's plates), and you do not have to pass emmissions ever again unless you sell the vehicle (at the end of 5 years you pay another $100 for registration for the next 5).
