column shift - th350 to 700r4 swap
Discussion in 'The Garage' started by crawlink5, Dec 25, 2003.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Will the column shift still work, although letters won't line up?
    Thanks,
    Doug
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes is same, dont worry about not being able to get into lo 1 on the 700r4, worry about that later when you can modify end of colummn so that the shift lever will go downwards a ltitle more, requires soem filing of the slot the arm lever rides in on end of column
    liek you wil need to get into lo 1 anyways....
    happy tranny swapping!
  3. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    You can use it the way it is. But, I plan on switching to something like the B&M megashifter. If you do this, the column shift doesn't matter.
  4. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    I'm certainly a fan of the megashifter. Just trying to keep body and interior stock as possible.
    Thanks for the info,
    Doug
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ands then you wil have to deal with column shifter housing with auto shifter arm deal, that wont look right, unless its a beater rig and it doesnt matter,
  6. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    Mine is a daily driver, not a show rig. But its not a beater. I plan on pulling the pin on the column and locking down the column at the firewall. After getting my 700r4 rebuilt the way I want it, the megashifter is next logical step.
