Combining a 6in lift and 3/4 ton axles
Discussion in 'The Garage' started by fourwheelinj1, Nov 12, 2002.
  1. fourwheelinj1
    fourwheelinj1 Registered Member
    Sep 18, 2002
    18
    Wake Forest North Carolina,USA
    Generally i know that you have to lengthen your drive shafts when you put on a 6 inch lift, but i was wondering if i could get by without lengthing the rear shaft because of the added length of the pinion on a 14 bolt. If so i will also be swapping in a 3/4 ton front axle, so could i get by with just a driveshaft spacer in the front? What is involved in installing a spacer. The blazer is a weekend play vehicle that will be mudding and trail riding lightly, prob less than 5000 miles of driving a year. I would prefer to not have to get a cv driveshaft or longer ones, since i am on a tight budget. I want to put 35's on and winch up front, so i am afraid i will have to trim more than i want with only a 4 inch lift. So will a combination of shims and tranfer case lowering be able to get rid of most of vibs.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    You could get by with the front spacer, but its still gonna be stretched out a little bit.
    The 14FF pinion does not stick out further than a 10 or 12 bolt rear. They stick out the exact same distance. This has been discussed before and a few of us have measured some axles laying around, like I had a 10 bolt and a 14FF laying in the yard, and measured the pinion stickout. They were both in the same ballpark, so rule that out. /forums/images/graemlins/wink.gif
    Try looking for a longer driveshaft, like out of a SWB or LWB truck and have it shortened to fit your truck. This is still cheaper than having new shafts made. /forums/images/graemlins/wink.gif
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If you are only going to be doing light trails and mudding I would just go with a 4" lift. I had 4" and 35" SSR's on mine with just a minor trim. I had to cut the corners off the wheel well opening at the bottom. That was with a 14.50" wide tire on a 10" wide wheel.
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Here is a pic.
  5. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    what kinda lift ya got there, cowboy?
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    With a 6" lift and 3/4ton axles, I still had to have a longer rear driveshaft made.
    The front worked, but don't expect a lot of axle droop - if you do, the slip will seperate.
    So basically for the front, it's OK but try to get it lenghtened when you can.
    If I had it to do again, I think I would have gone with a 4" lift instead of the 6".
    -- Mike
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm a firm beliver in doing things right so I don't have to keep fixing things. So I broke down and had new shafts made with all new components. Each shaft ran me about $200.00 . So roughly $400.00 for both.
