Combining stock front leaf springs with 52" rears?
Discussion in 'The Garage' started by 88K5Jimmy, Apr 14, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Combining stock front leaf springs with 52\" rears?
    I got to thinking, could you take the top leaf of a factory set of 2nd gen front leaf springs and then add everything minus the top leaf of the 52" springs people are swapping in? If I'm thinking right, this would keep the axle at the factory position but still give the soft ride everyone is saying of the 52" springs.
    Thoughts, comments, criticisim?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: Combining stock front leaf springs wtih 52\" rears?
    on thing that makes them soft is the length.
  3. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Well you could but isn't your front a 3" spring and the rear a 2.5" wide spring. Also the stock front springs are setup for reverse arch and the rear are positive arch...seems to mee they woulden't set together nicely.
    I did that to a set of front lift springs and it worked very well...but I ended up bending the 2.5" wide main leaf...thats why I now use 3" wide ford springs in the front.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    GM springs are 2.5" wide. That wouldnt work too well I would think. The GM's work soo well because of the entire pack's softness. I would just move your hangers are redrill the main leafs to move the axle back to stock location. But you loose some of the benifits of using hte 52's when you do that.
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I didn't even think of the difference in spring width. Thanks guys
  6. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    Re: Combining stock front leaf springs with 52\" rears?
    I did this a couple of years ago on my '75. It was a little rough ridin, but I didnt care I just wanted the height. I used both stock front leaves plus all the rear leaves except the main leaf and the overload. It didn't flex very well but gave me about 4" of lift.
