come-along help
Discussion in 'The Garage' started by 84gmcjimmy, Jan 9, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I am getting really frustrated...
    I brought the old come along out to see if I could drag the jimmy sideways into it's old tracks... well it didn't move and now I can't release the come along cable... here is a pic
    http://coloradok5.com/photos/data/500/15029PANA0808.JPG
    I don't have a clue how to release it, before all I did was press that bent tab and the cable would come out... I hit it a few times with a hammer to see if it would release, but it just bent...
    SO... I was wondering if I can just cut the cable with a grinder...
    This is how it looks from 20 or so feet away...
    http://coloradok5.com/photos/data/500/15029PANA0807.JPG
    If I were to cut the cable, would it just fall to the ground, or is there a chance something would try to hit me in the face? I'm throwing this away after because it has never worked from the beginning when my dad bought it.
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    try pulling on the handle so you tighten up the cable a little bit more, then press the tab, the handle will now go backwards and losen the cable a bit, then you have to keep doing that untill you have enuff slack to take off you hook.
    if that dosent work and you want to cut it. throw an old coad or blankit on the cable and stand on the chain side. and use bolt cutters if you have them if not then the grinder
  3. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    oh and steve click on this :[​IMG]
    and paste your url in there!:waytogo:
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I am kind of leary (sp?) of pressing on the tab because I don't want to get my finger caught in it. I can't pull it anymore without using my full bod weight, and then I cant hit the tab.
    I can't cut it if I am standing on the chain, it's so tight that when I jump on the chain, the whole Jimmy wobbles. I can't get the chain on the ground long enough. :(
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL I kow how to do it, but when I press it it won't paste in, then it says "null" when I close it and reopen it... its weiiiiiiird!
  6. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    DO NOT!!!!! cut the cable!!!!
  7. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    x2
    doing that may get you a darwin award
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Why?
  9. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    you've been having hell of a time with thatlast couple days man that sucks good luck :mad:
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I wouldn't cut that cable. You have a very good chance of getting hurt or even worse. If there's tension on it, as you describe, it will snap back in an unpredicatble direction, actually both cut ends will snap back in unpredicatable direction. Find a way to take the tension off. If you have another person, you pull the handle to take the tension off the release lever and have the other guy push the release.
    If no other person is available, get another truck and push/pull that jimmy just enough to take the tension off the cable. Even a car would work, you wouldn't have to move it much probably. If the Jimmy runs, try to move it back just enough to take off the tension. Anything but stand over that cable and cut it.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Well I tried backing out and I didn't get anywhere far enough to un-do the cable.
    I actually cut it, I was just wondering why I shouldn't. There wasn't a god awful amount of tension on it. When I cut it it shot back 5 inches and then it dropped. I had a piece of 3/4" plywood in front of me just in case, I also had a sweatshirt over top to weight it down.
    I didn't know what else to do. I'm fine, but I realize what your saying, I shouldn't have done it. in the future I won't do it again.
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    because you will hear a 'TIIINNNNNGGGGG' then you might fall to the ground screaming reaching for whats left of you leg if your lucky enough for the cable not to hit you in the head....
