Common gear ratio for 80's 3/4 ton diesel Chevy w/14bolt sf
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Feb 7, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Common gear ratio for 80\'s 3/4 ton diesel Chevy w/14bolt sf
    I'm hoping 4.10's but what do you guys think?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: Common gear ratio for 80\'s 3/4 ton diesel Chevy w/14bolt sf
    I'm thinkin you'd most likely get 3.42's...Alot of diesels seem to have that ratio. /forums/images/graemlins/pimp1.gif
  3. BanksBurban
    BanksBurban Registered Member
    Mar 23, 2002
    88
    New Jersey
    Mine came with 4.10's
  4. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    Mine has 4:10's from the factory but its not a diesel
  5. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,594
    767
    City of Sand, UT
    3.42 is what alot came with because diesels run so slow (3000rpm redine) but for trailwork, 3.73s would be a good compromise. if yours is a trailerqueen, (as its probably not) or back roads to the trail, 4.10s would be best. i wouldn't go any lower unless you have big tires, then you should keep it higher than you would a gas rig.
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    The one I got out of the diesel sub was 3.73
    John
