comp cam
Discussion in 'The Garage' started by stick, Jun 4, 2005.
  1. stick
    stick Registered Member
    Mar 24, 2004
    76
    omaha
    any body used a comp cam without the comp lifters? does every body who uses this cam go ahead and replace the springs? :confused: oh and what do they mean by "flat tappet cam"?
  2. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    the lifters are flat where the meet the cam which is different from a roller (which has rollers).
  3. stick
    Mar 24, 2004
    76
    omaha
    okay, now i get it.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    you will generally void any cam warranties if the recommended springs and lifters aren't used.. not that it wont work fine...
  5. stick
    Mar 24, 2004
    76
    omaha
    hell, i didn't think a cam would turn into a $400 job
  6. dyeager535
    26,980
    $400, what kind of cam and lifters are you looking at?? That's aftermarket roller lifter price territory.
  7. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    me and a friend have had bad luck with comp lifters. but cam and federal mogal lifters work great.
  8. stick
    Mar 24, 2004
    76
    omaha
    bad luck? what sort of thing happened?
  9. sweetk30
    Nov 1, 2004
    25,548
    543
    less than 5k miles bad lifters and flat lobes. but comp cam and fed lifters o.k. still running great.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my buddy has had bad luck with the federal mougal lifters, lasted like 2000 miles. put comp lifters in and no problems. i run comp lifters in all my motors. works just fine.
    i believe the lifters void the warenty, but the springs are just a recomendation don't void the warrenty. if i miss read the instructions, then all my cams are void if the cam takes a ****. i use the Z28 spings.
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    err I called comp cams.. he recommended the xtreme 4x4 cam for me.. I asked about buying new springs and lifters... he said....no need to.. :crazy:
  12. dyeager535
    26,980
    I *thought* that almost all lifters were made by FM anyways. I'm curious to hear if anyone knows differently.
    On top of that, how many have actually had a cam fail due to manufacturer defect immediately after fire up? Not starting an argument, I thought about that when warranties were brought up.
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    federal mogul's lifter and bearing plant is 11 miles from my house. ill have to ask someone who works there.
    they are not the same as comps lifters. if you have the 2 side by side, there are major differneces.
  14. Wes Harden
    Wes Harden Registered Member
    May 28, 2005
    29
    Southern Califorina
    Comp cams had a bad run of heat treated billets allthough you will never here it from them. If you don't break/run the cam in correctly ,any cam but a roller , you will most likely have flat lobe in few thousand miles.
    Flat tappet lifters refers to mechanical ie solid lifters then you have hydralic flat tappet and roller lifters.
    Lots of good info on Comp cams web page and good description on how to break in a new cam.
    Also the cam specs normaly determine which springs you need.
    Wes
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I always buy the "K" kit. I only run Comp Cams.
