Comp Cams Xtreme 4x4 Cam Kits
Discussion in 'The Garage' started by RATAH, Nov 2, 2003.
  1. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    If I ever recam or build a new motor I will likely go with the most mild Comp Cams 4x4 cam. aka I hear nothing but good things
  3. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I went with not the lowest one but the next to lowest one. Not sure what kind it was. Haven't got the truck on the road yet but it sounds awsome sitting in the garage. Nice rumble when idiling.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have the 254H 4X4 Xtreme. It is a great cam for my 388. /forums/images/graemlins/thumb.gif Although I have thought about going one size bigger. /forums/images/graemlins/thinking.gif
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have the second to lowes one and it works great. I got the K-kit, so it came with the double roller timing chain, matched valveprings and new of course, new lifters. Some other stuff too I think...
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had the smallest one and it had loads of torque. /forums/images/graemlins/smile.gif
  7. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    i've got the comp 262h 4x4 extreme and its an awsome cam great power through the entire rpm range. the engine that its in is my 73 stepside.
  8. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    I've got the lumpiest 4x4 extreme roller cam in my 406 and all I can say is wow. Probably not the best for crawling, as it doesn't make its torque peak(540lbs) until about 4400 rpm, BUT it still makes 380lbs at 2800 rpm. Its got enough on the bottom to roast locked 40's on pavement with an auto tranny. /forums/images/graemlins/grin.gif I like being able to creep when I need, but still have the balls to play at the mud drags.
