comparing spindles (3/4 and 1/2 ton)
Discussion in 'The Garage' started by AKbigsub, Jun 6, 2006.
  1. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    are the front spindles on a 3/4 ton the same or different than a 1/2 ton? And if they are the same, are the bearings the same also? And lastly, are the knuckles the same or different?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Everything is the same in big bearing stuff except the hub of course.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    And the only difference in the Hub is the # of wheel studs:D
    Ira
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Spindles are the same, knuckles are the same, calipers are the same, (except for the different brake system, which uses a different pad) the different parts are the brake backing plates, hubs and rotors.
  5. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    DIFFERENT PAD ?
    I installed my 1/2 ton calipers with 1/2 ton brake pads right onto my
    new 3/4 ton rotors and backing plates, and all fit well. should i be expecting a problem ? do i need to go buy 3/4 ton brake pads ?
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    no, all i am saying, is there IS a different style for one of the other braking systems on the Chevy truck, i honestly don't know what it is, someone on may know, but this "other" brake pad has two big ear type things towards the top, and goes into a totally different caliper.
    For the most part, you use the 1/2 ton style pads though.:D
    here, i found a pic of thos other style pad,,,
  7. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    cool .
    as for those pads in the pic, they look nothing like mine.
  8. goldwing2000
    goldwing2000 Guest
    Of course, this is all assuming that you have a 10-bolt or a newer D44.
    Older D44 axles have different hubs and spindles, as noted in this article.
    If you needs hub/rotors and backing plates, check this thread.
