Competition questions
Discussion in 'The Garage' started by crazyrc, Nov 24, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    I would like to compete in Canada's version of Top Truck Challenge...(Extreme Showdown). Firstly I have no intentions of being able to win as you have all seen that there are some very serious rigs up here. I would like some advice on other mods that you would do if you were me.
    Most of the info you need is in my sig, except the twin stick 205 and 9500 and 12000lb winch. I'll probably just run the front winch in the comp though.
    Doubler is out of the question at the moment, but all other suggestions will be considered.
    First mod will be a hydro assist and crossover, and maybe offset zero rates to help approach and departure angle.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Three letters.
    E-F-I
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I'm interested in your 406, whats done to it?
  4. crazyrc
    Jan 20, 2003
    106
    Edelbrock RPM intake
    Holley Truck Avenger Carb
    MSD 6AL Ignition, coil, billet distributor
    9.5:1 compression
    Dart Heads with many,many hours on the flowbench also larger valves 2.05 intake ???exhaust
    Comp cams 4x4 extreme roller cam They make three variations of this cam...I went with the lumpiest. Still makes solid bottom end, but gets really good after 2500. /forums/images/graemlins/thumb.gif
