Complete Bed Replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stickman75k5, Aug 8, 2002.
  1. stickman75k5
    stickman75k5 Registered Member
    Apr 16, 2002
    7
    Has anyone looked into replacing their entire bed and sidewalls with a complete new bed from a shortbed truck. I can get a new (foreign made) shortbed for about $800. I thought it might be possible to cut the excess off at the front end of the bed and make a similar cut on my Blazer. I could then unbolt and remove the entire rear section and drop the new one in and weld just behind current door posts. This would solve the rusted tailgate and bed problems and enable me to use a regular truck tailgate once I get the soft-top for it. Granted there are minor concerns about rear seat mounting and gas filler locations, but these should be able to be overcome. Any thoughts or comments would be appreciated.
  2. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    been done many times, get a rear floor straight from gm for around $375. and your set. if your quarters are shot im sure you could replace them as well with aftermarket and have less trouble than choppin up for a short bed box. do a search many have outlined it in detail.
