complete pto ignorance
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wbmoore, Jan 6, 2002.
  1. wbmoore
    wbmoore Newbie
    Jan 6, 2002
    4
    Northern California
    Be gentle......I have a C/30 flat bed which I want to turn into a tilting bed. It's done with a hydaulic pump, control valve and a couple of rams.......that part's easy. However.........to power the pump, I need a PTO. Here come's my ignorance.......is a PTO the same as a transfer case ??? I thought I needed a NP205. Maybe I'll just go electric motor.
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    transfer cases have a pto cover on the side where you can unbolt the cover and there is a hookup that spins even when the transfer case is in neutral (transmission in drive)..
    i found out recently that even manual tranny gearboxes also (most of them) have a PTO capability.. so it doesnt have to be 4WD. hope that helps
    mike
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep. You're right. Both my 205 and my SM 465 have PTO covers.
    You either have to have a manual tranny or a transfer with a pto output to use a PTO I guess.
    Tim
