Complete Steering Column Re-build?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Nov 27, 2001.
    Hello all!
    My steering column is wacked! I have about 2-3 inches of play in it up and down, right to left there is about 2 inches. It's like the tilt went out or something. It's really freaking me out, I am sure this is not normal. How should I go about fixing this thing? Is there something to tighten, or should I just sink the money into a complete replacement/re-build
    '84 K5
    Chevy in my blood.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    <a target="_blank" href=http://www.dorianyeager.com/column.html>http://www.dorianyeager.com/column.html</a>
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  2. schwinnd
    schwinnd 1/2 ton status
    Feb 26, 2001
    109
    SE Washington
    I got a non-tilt column from the junkyard for $50 and permenantly fixed the problem.
    Just collecting rusty mid-70's chevy's
    1976 Blazer, 1975 Vega SW
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds like you need a new bearing kit, and the standard tightening procedure - a few hours, alot of cussing, and about 20 bucks and you'll be good to go[​IMG]
    Pics here:pugsley.alloffroad.com
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    thanks pugs I couldn't figure out how to post yours... But I tried....
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm not sure I ever actually posted it - normally I just copy and paste it from MS Works[​IMG]
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Then where did ya get it, I could'nt find pics on Dorians site, and you have pics... Cool info none the less...
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Ladies and Gentleman... I present... The Grim reaper award [​IMG] LOL... long and of course as most of grim's posts are... very informative. Good job Pugs! You should send in some of those to Steve. *Drama voice* You could have your name in lights on the WWW... you could be a star [​IMG] LOL.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    There is also a company that will come to where the truck is parked and fix it for $50 bucks. I have had them do a couple of my trucks. They advertise in the parts section of the AZ Republic on the weekends. That's if you don't have the time.
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  9. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    Mine was doing what yours is doing... And even got so bad as when i would turn the wheel... the truck would shift gears!! Anyway... Mine was not rebuildable. There was something damaged that can't be replaced.. Don't remember exactly what. I ordered a completely rebuilt one, which came looking like brand new. I got it from Empiresteering.com The guy that runs the business is a very nice man. He has a tech board on his site also, he will answer any questions you could need.
    Sara
  10. dyeager535
    26,982
    191
    You forgot "stop using the wheel to pull yourself into the truck and you wouldn't have this problem" in the writeup" : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  11. Blazer83
    Blazer83 Registered Member
    Aug 31, 2001
    26
    Houston, Texas
    It was quite ironic, I was just complaining to a buddy of mine about this very problem and actually contemplating putting this out here on how to fix it when I looked down and found this post. Talk about timing..... Thanks Guys................
  12. shooter
    shooter Registered Member
    May 24, 2001
    18
    Colorado,USA
    I am going to use what you wrote and the pictures, thanks for writing this. Is it a matter of just tightening or can I expect to replace some parts??? Thanks again.
  13. Thanks Pugs! I printed that out (after a cut and paste of my own) and will try to do the job this weekend. Although I have given serious consideration to just replacing all of it!! From the steering wheel down to the box and pump, why not right? Then I will know that that part of my truck is sound.
    Now, if I could just morgage Park Place and a Railroad I should have enough money...hehe
    Thanks again!!
    '84 K5
    Chevy in my blood.
  14. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    sounds like this is a common problem, mine is loose too.
    anything that worth replacing while in there? or is it just a basic tightening that most k5s need.
    <font color=blue>85 blazer</font color=blue>
    <font color=blue>88 blazer</font color=blue>
    <font color=blue>99 30th ann. TA</font color=blue>
    <font color=blue>79 TA</font color=blue>
  15. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    When I open them up, I like to cruise to the dealer and pick up a replacement upper bearing kit (around $18), and an ignition rack/pinion kit (around $15) - it became a habit after that damned rack broke on me 2 days after tightening the column up on my Granddad's K5[​IMG] Past that, it's just tightening and lube[​IMG]
