Complete TBI 454 - reduced
Discussion in 'Engine | Tranny | T-case' started by longbedder, Apr 4, 2007.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Stock 1993 TBI 454 in great running condition.
    Comes complete with:
    • all brackets and serpentine belt
    • alternator/AC compressor/PS pump
    • wiring harness and computer
    • K&N air filter & complete housing
    • Exhaust manifolds, Y-pipe w/ O2 sensor and bung
    • TBI Suburban gas tank w/ in-tank pump and braided steel hoses
    • No leaks
    $850
    In SoCal, no shipping.
  2. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    How many miles and did you have any problems with it when you had it running. Anything that you would recommend I do to it?
    What type of vehicle did it come out of????
    PM, me your number!
  3. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    I bought the engine for a project that I never got around to. I have been reassigned across the country and have to let it go.
    It was running great with no issues at that time (last year). I'm unsure of the mileage, but there are no knocks, no leaks, etc. It doesn't need anything internal, but it has no starter.
    If you put it in an old truck, you'll need a vehicle speed sensor mounted on the transmission - you can buy those from www.jtrpublishing.com
  4. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    longbedder, the VSS that you told me about would I need just to hook up the VSS sensor to the transmission and would I also need the computer for the VSS hookup?
  5. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    This may get complicated, but here goes...if you read all of it carefully, it's not hard or expensive. This is based on what I learned when researching for my project.
    On the original truck, the VSS consisted of a 40-tooth metal ring called a reluctor ring pressed onto the output shaft of the transmission (or transfer case if 4WD). There was a sensor threaded into the tailhousing that would send a pulse every time a tooth on that ring passed, therefore it was sending 40 pulses per revolution to a little electrical box called a DRAC. The DRAC then performed some operations on the signal and output it a couple different ways: one to the electronic speedometer, one to the antilock brakes, one to the cruise control, and one to the ECM. The ECM signal is the only one you would care about. The signal was dependent on the tire size and gear ratio of the particular truck it was in.
    Option 1:
    Now, you may want to just go the route I described above. You could either get a 4L80E or 4L60E transmission, or press a reluctor ring onto some other transmission and then drill and tap the tailhousing or transfer case housing to mount the sensor. That would give you a stock setup, but may be out of your reach mechanically or financially - I don't know.
    Option 2:
    Jags that Run (www.jtrpublishing.com) also sells several different VSS's that simply screw inline with your mechanical speedo cable. You could get one of those, get a donor DRAC from the junkyard for $10, and tweak the DRAC to get the correct output pulsing (assuming you or a friend can do algebra and run a soldering iron).
    Option 3:
    Buy a 2 pulse per rev cable-driven VSS (part number 2PRS from JTR), screw it into your speedo cable output, and run the leads directly to the ECM. The pulsing rate won't be exactly right, but it will be pretty darn close and won't damage anything. For example, with the 2-ppr, 33-inch tires, and 3.73 gears, you would get 2279 pulses per mile into the ECM (instead of 2000). This way it wouldn't run any different than a new truck would if you put non-stock-sized tires on it and never reprogrammed the computer, and people do that all the time. $79 + 10 minutes labor and you'd be in business.
    Option 4:
    You could just ground out the Park/Neutral safety switch. The engine won't run optimally this way (no VSS), but it will run. I wouldn't recommend it for the long haul, but it's OK to get started.
    I believe that the computer I am selling with the engine requires 2000 pulses per mile. You could email/call the guy who runs www.tbichips.com and he could probably tell you for sure - that's something I never got around to. The ECM service (part) number is 16147060.
  6. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
  7. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    um, $1k?
  8. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    buuuuump
  9. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Anybody for $850?
  10. Element
    Element 1/2 ton status
    Mar 23, 2007
    314
    WV
    If you were on the East Coast, I'd take it in a second, but I think shipping would cost as much as the engine.
    You'd figure in a redneck state like WV, it'd be easy to find engines, but hell no.
  11. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    trade ya for a 97 GSXR 750 that needs some fairings painted.
    ~Brian
    PS Im in socal and will pic up.
  12. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
  13. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Sorry - sounds cool but I'm trying to get rid of stuff before I move across the country.
  14. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    I'll see if I can get this thing sold quick. If I can I will buy that engine. I want it bad.
    ~Brian
  15. FlagBurb
    FlagBurb Registered Member
    Oct 3, 2002
    58
    Tucson, AZ
    Where is the 454 located?
  16. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    Southern California
    ~Brian
  17. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Still got it...
  18. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Last call...
    Not dropping the price anymore, and I leave next week.
