Compression check
Discussion in 'Other Rides' started by BowtieBlazer, Jan 7, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I just did a compression check on my brothers 1990 Mecedes 190E 2.6L and i was looking for the compression specs. Anyone have a ballpark figure? I called the local Mercedes dealer and the guy claimed not to even have a book on that car. Any help is appreciated
    Granny LOW and let her GO!!
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    On gasoline engines the compression will usually range from 100 - 150 PSI, diesels will be much higher, the cylinders should all be close to the same reading. the indicator of problems is any cylinders which are considerably lower than the rest. Be sure to block the throttle open when testing to allow the engine to get air, if it pulls against the closed throttle plates it can affect the readings.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454
    </a><P ID="edit"><FONT class="small">Edited by 95 Silverado on 01/08/02 09:05 AM.</FONT></P>
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    Thanks!
