Compression Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jun 24, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    OK, I have a dumb Question. If your timing is off will it affect
    your compression. Mine is low (about 120lbs in cyl 1&3 )I did not check the others and I know my timing is off but I don't see how it could change it that much If at all. Any input
    I also thought I would add that the oil pressure is jumping,the lifters are tapping,and every once and a while I get a healthy
    backfire through the carb
    HEY Fords!!! how many flushes does it
    take to get rid of you<P ID="edit"><FONT SIZE=-1>Edited by Redfrog on 06/24/01 01:11 AM (server time).</FONT></P>
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    no it will not affect the compression if your distributor timing is off. Now if the cam timing was off, then you'd have trouble.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
