Compression ratio questions
Discussion in 'The Garage' started by 88-383, Mar 13, 2006.
  1. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Do you guys think 10.1 is to high for a K5? The enfine is built 355 with aluminum heads, full blueprinting and balance. I don't mind having to use high octane fuel, but i don't want it to blow up either.
    Kelvin
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    With aluminum heads I think 10:1 would be just fine, but you will have to use premium fuel.
  3. dyeager535
    26,982
    191
    What kind of heads besides aluminum?
    I think one rule of thumb states you can go a full point on compression with the same gas.
    I'm running 9.2:1 with 87, you probably can with AL heads @ 10:1 if they've got a good chamber.
  4. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Especially okay if you can use small cc combustion chambers and flat-tops to achieve 10:1.
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    stupid question.... how do you determine your compression ratio???? :crazy:
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Oops, the previous poster already dealt with what I was going to post.
  8. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    I'm using the 195cc Trick Flow CNC heads on this engine. Normally I would've had the block zero decked, but some reason this time I didn't. Would you guys say it'd be ok even towing?
    KM
  9. dyeager535
    26,982
    191
    Are these the Kenny Duttweiler models? I can't find the 195's on TFR's site, but I do see some 23* Kenny Duttweiler ones there.
    Looks like fast burn inspired chambers on the 175 non-Duttweiler models, so if the Duttweilers follow suit and are also fast burn, I would *suspect* (experience may prove otherwise) that you would be fine with 87 octane at that compression ratio.
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    yeah i dont know what im doing.. i came up with a 1.43 : 1 ratio!!! :haha:
    she should purr like a kitten
  12. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    Yup 195's you can see them here. Being able to run 87 octane would be a real bonus. I just wanted a sanity check because I don't want a pinging engine.
    http://www.trickflow.com/product/chevycylinderheads/23degree/pr_23degree.asp
  13. dyeager535
    26,982
    191
    What are your combustion chambers like? That's key to what kind of compression numbers you can expect to get away with, and that sight doesn't show on your 195's that I could find.
    If you are worried about it pinging on even super unleaded, I wouldn't worry at all. (just in case it does with 87 or 89)
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    The 195 is the intake runner volume, not the combustion chamber volume - more than likely your CC volume is either 64 or 70. They can be had in may other cc volumes depending on the mfr, but AFIAK 64 & 70 are the more common ones for small block Chevys.
    I'm running the Vortec heads on mine, and though I don't know the cc volume, they come in either 64 or 70. If it's got 64ci I'm pushing 10.48:1 (which sounds about right because it pings like a Diesel on anything less than 91 octane), or if it's got 70 I'm running 9.84:1.
    Mike
  15. dyeager535
    26,982
    191
    Yeah, I understand the CC volume vs. runner volume, it's just that the sight doesn't show a pic of the combustion chamber design. :)
    The other heads pictures do have the fast burn (used in the Vortecs) chamber design, so that was where I was going with it..10:1, AL heads, and a fast burn chamber *should* be pretty easy on the fuel.
  16. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Don't forget about cam timing playing a role in different motors that are being compared with the same C/R ratio's . What works in one engine might not work as well in another .
    Tom
