Compression Test Results, High??
Discussion in 'The Garage' started by mini_mull, Apr 6, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Ran a compression test when I replaced the plugs. (OK, my hubby did it while I supervised since I'm due next month) The numbers were all within 10% of each other, so that's good, but they seem a little high compared to other people's that I pulled up when I searched, what would cause that? Here's the results:
    8-190 7-177
    6-187 5-186
    4-180 3-183
    2-183 1-185
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    12 to 1 compression pistons! JK :D Good rings I guess?? I wouldn't worry about a high reading .... it's when they're low that you start to wonder :thinking:
    Eric M.
  3. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    sounds like you were spinning it too many times.. we usually go 5 "puffs" on the gauge..
  4. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Thanks guys, I feel better now. I guess we did spin it too many times. The directions on the test said 4 cycles or until it stopped going up. I just did the later for simplicities sake, I'll have to try the 5 puff method next time.
    My results should still be accurate as far as the variance between cylinders though, right?
  5. RustyMule
    RustyMule Registered Member
    Dec 18, 2004
    73
    Westford, MA
    From what I know, it tops out after 4 or 5 "puffs" anyway. You could spin it all day and it won't really get much higher. And higher is never bad. :grin:
  6. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Looks fine to me, just crank till the guage stops going up...
  7. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Actually those numbers are pretty right for a bone stock tbi motor in good shape. The stock cam and heads are designed to fill the cylinders up at low rpms, causing high readings. Heck the motor in my suburban hits 160's with a much bigger xtreme 4x4 grind cam. Sounds like you've got a nice healthy motor that you don't need to worry about it. BTW readings can vary as much as 10-20 lbs on identical stock motors due to stock variances in deck height and such. This doens't even call into effect atmospheric pressure that day, so i'd say you're good to go.
  8. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    you can have carbon coated on the piston and the heads which increases the pressure
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    yep. carbon buildup = higher compression. :blush:
  10. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I thought if you had a lot of carbon buildup it would run rough or sputter. It doesn't run bad, pretty strong, in fact, especially for a motor w/ 214K. Should I be worried about that (carbon), or only if it starts effecting performance? Is there any way to clean it off short of tearing it apart? That's not exactly an option right now. Some kind of oil additive maybe? I don't really want to do the water thing, too nervous about home brew remedies on a DD, with no $ to fix anything that I mess up for at least a few months. Thanks for the info. Keep those explanations coming please.
  11. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    there is really nothing you can do without tearing it apart except for valve cleaner... any kind of oil additive won't get to the top of the piston where the buildup is the worst. I wonder if one of these guys is going to come up with some sort of solvent i've never heard of that you pour through the valves once you get the cover off...
    Carbon buildup doesn't necessarily mean a weak motor... it depends on where the buildup is. If you have a lot of buildup on the valves or exhaust port then you can expect sputtering and less performance. besides raising compression the buildup on the top of the piston shouldn't hurt anything, its the other pieces that you have to worry about.
  12. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    you could Seafoam it....
    but i wouldn't bother, considering your looking to repower it sometime soon anyway and it runs good..
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    10% is cool. Keep cranking 'till it stops moving. If it seems high you've either got a throttle that opens more than other peoples(you are doing this on WOT aren't you?), got a carbon build up or your motor's a bit smokey and the oil helps seal the rings up giving higher comp. :)
    Good luck with the sprog!! :D
  14. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Thanks guys. Guess I won't worry about it for awhile, if it's not going to hurt anything, at least until I can actually do something about it. That's a relief. :D
