compression test
Discussion in 'The Garage' started by sunnyc123abc, Sep 30, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    So what am i doing wrong here. I just got a 350 and im trying see what the compression is. So i take all the plugs out, and plug in my compression tester. Since the engine is on a stand i turn the engine over using a rachet on the balancer. But im not getting any readings. This is my first time, so im kinda learning as i go. Thanks
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    no you have to spin it with a starter. and only 1 plug at a time. no compression in the 7 other cylinders would spin the crank faster cause theres no compression resistance.
  3. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    ok...i thought that would be it. Thanks. Damn, I took the flex plate off before i put it on the stand.:doah:
  4. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    So how am i suppose to crank it on the engine stand if the flex plate won't fit. Any ideas:confused:
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    take it off the stand and just block it off on the floor.. We do it all the time at work... Piece of ply under the pan and block up to the motor mount bosses...
  6. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    ok, ill try that..thanks
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Hell, i used to fire them up and run them on the garage floor.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, us too... Hook a hose to the rawpump, 5 gal jerry can, let er rip! :wink1:
