compression to high???????
Discussion in 'The Garage' started by sjeccles, Jan 19, 2003.
  1. sjeccles
    sjeccles Registered Member
    May 13, 2001
    27
    Iowa
    Is it possible that rings have trouble setting because of to high of compression? I have about 3000 miles on my engine and it still burns a lot of oil. So I pulled the spark plugs and all 8 of them were very oily. I did a compression check and all the cylinders were 230-240 psi. So I’m wondering if the compression is just so high that the rings can’t get seated. I’m using chromoly rings. Originally I was going to run 76cc heads but found a good deal on some 58cc heads so I used those. This might be my problem
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That does sound pretty high. Do you have trouble with pinging?
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    That is too high for 92 octane. The highest cranking compression for 91 octane is 175-180 psi. Also cromoloy rings take longer to set. Another thing is you could have too big of a ring gap.
  4. sjeccles
    May 13, 2001
    27
    Iowa
    I have not noticed pinging but it a TBi so the computer and knock sensor could be retatding it before I could hear it
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm not a fan of the 305 heads (58cc) I really like 64cc heads like These heads [​IMG]
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    If the timings getting that retarded, you might be shooting yourself in the foot to make decent power. Might consider swapping out the heads. /forums/images/graemlins/tongue.gif
