Compression
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Aug 16, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Does anyone know what compression my 350 came with from the factory. I am thinking about getting a compression tester that you put in the spark plug hole to test it. Wouldn't this be for the engine to run on 7 cylinders though? Thanks
    90K5
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If you mean comp.ratio it is 9.3 to 1. A compression tester won't give you compression ratio.
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Also you don't run the engine with tester in the hole . Just turn it over 3 or 4 cycles .
