Compression?
Discussion in 'The Garage' started by Tshane, Feb 11, 2004.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    Today I check the compression of my engine and the tool I was using measured it in lbs per sq. in. I was wondering if there is a formula to change that to a proportion (ex. 10:1).
    /forums/images/graemlins/truck.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    At sea level, the atmospheric pressure is 14.7 PSI. So let's do some math:
    If your compression tester showed 147 PSI, then 147/14.7 = 10 would give you roughly a 10:1 compression ratio. 135 PSI would work out to 135/14.7 = 9.18.
  3. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    BTW, there's a fudge factor that will vary from engine to engine, so don't expect an exact figure. Due to various cam timing, valve overlap, etc. the pressure from the compression test is not a perfect repesentation of the mechanical compression ratio. A really radical cam will show low compression pressures simply because it has so much valve overlap. This causes some of the air to be expelled from the combustion chamber before the valves are fully closed. /forums/images/graemlins/eek.gif
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Of course, if you spun the engine faster, I am pretty sure you can make the PSI come up too!
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Not by much. Spinning faster won't result in much of an increase in PSI because the compressed air is allowed to escape through the exhaust valve during stroke 4 of each complete cycle. You could probably see some increase with a radical cam if you could get the engine to spin at say 5,500 RPM. At that point you would be in the sweet spot of the cam, where the combustion chamber is able to pack in more air due to a mini "ram air" effect of the long valve overlap.
