Compressor coming on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rebel88, Sep 11, 2000.
  1. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    When I start my 88 and let it idle the A/C compressor keeps clicking on and off. The heater/A/C controls are all of and the fan is off. I played with it one day and ended up pulling the fuse out of the fuse box for Heater/A/C. Then when I started it up it stopped happening. Is there a short in my switches or a bad connection or what? If anyone has had this problem or knows what to do please let me know.
    Thanx
    Have you driven OVER a Ford lately?
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>I am not an expert on A/C, but it does sound like there may be a short in the switch or lever. There is a clutch cycling switch, however it should not have power if the switch is off. - Steve :)</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  3. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    hey sosaman,
    where is the cycling switch? right now i am riding around with no fuse in the fuse block so i have no vents/no nothing. i appreciate anything you can tell me.
    Thanx
    Eddie
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    There is a connector on the front of the compressor that supplies voltage to the clutch, remove the connector and replace the fuse, it should not cycle on you now.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    There is a switch that is activated when the heater controll lever is put in the Defrost posistion .This switch cycles the A/C compressor on and off even when heating. It designed to do this to keep the compressor lubed up and cycle the refrigerant in the winter.
    This switch should turn off when the heating controll lever is moved to heat or vent position. Your problem is most likely in this switch. It is either stuck closed or your heater contolss are messed up. Gotta pull out the heater controlls to fix it.
