compressor tech: How to not light your new to you, FREE compressor on fire!
Discussion in 'The Garage' started by masterbeavis, Jul 28, 2005.
  1. masterbeavis
    masterbeavis Registered Member
    Aug 10, 2004
    20
    El Dorado ca, East of Sacramento
    This little gem right here.
    It has been sitting long enough to be not good for it. I was trying to start it with ether first, ran out, so switched to brake cleaner. I had one little small backfire and WOOSH, lit the carb and gas tank on fire. Lucky me I didnt have the gas cap on either.... :eek: I blew on it 3 times like a birthday candle before I figured out it needed something else.. Lucky the elec pressure washer was on, put it out with that....
    Moral of the story is... Dont use ether to start motors, put the gas cap on the tank, have something ready to put out the fire!! :bounce:
  2. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    i found an old electric compressor about the same size as that in a barn, it ran great for a while then siezed right up mid-use. I banged the crap out of it with a BFH and a chunk of wood, got it loose, put some nasty 10w30 i had from my truck in it, worked ever since. its a trooper!
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have that exact same compressor. I dont use it much because I have an electric one in my shop. But it runs great and pushes a lot of air.
    Prolly will need to clean out the tank and pull the carb off and spray some carb cleaner thru it. Clean out the screens on the pick up tubes. ECT ECT.
    Its a good compressor and worth fixing.
  4. masterbeavis
    Aug 10, 2004
    20
    Tore down the carb tonight. Will get a new diaphram and misc. other small carb parts. It wants to run.......
