Computer Controlled Distributor or Not
Discussion in 'The Garage' started by WRENCH-HEAD, Mar 29, 2006.
  1. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I installed a Holley commander 950 tbi kit and I wanted opinions on whether or not I should let it control the distributor. I currently have a Pertronix Flamethrower HEI distributor and I was curious if it was worth it to find a HEI with the 4 wire plug that the holley can directly plug to. I could use the Pertronix coil, but not the module if I did this route. All opinions wanted. TIA
    -ALEX
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I got a computer distributor I'd sell ya if you wanted the best setup possible . Its a unit with no advance at all , no mechanical , no vacuum . Just a regular looking coil in cap with a 4 pin weatherpack connector .
    Don't know where it came from it was on the 283 in the Chevelle when I pulled it :thumb:
    Anyway , the advantages of the computer controlling it all are the fact that you don't have to worry about the advance curve . The computer would do it on the fly alot better than a mechanical setup would .
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    You trust the Holley computer to control your engine's fuel delivery, but aren't sure if you can trust the same computer to control the same engine's spark advance/timing. Is that pretty much the situation?
  4. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Not a trust issue, just a matter of if I will gain anything. I'm not looking for every last drop of power, just drivability and running quality. I like the simplicity of the one-wire HEI and if anything goes south on it I can go to any parts store and find parts for it. Just curious if it was worthwhile to have the holley control the timing for efficiency. I know when retrofitting factory tbi you have to use one, but if it was optional what would you choose?
    -ALEX
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are stil one wire HEI . And will run without the computer plugged in , albeit crappily with no advance , but it will run without the computer .
    I know , I drove mine mine home :thumb:
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    I'd say its well worth it. You can get that timing setup to suit your engine best, not work with every engine out there generally :)
    If your engine likes lots of timing right outta the hole, and backed off later on, it can be done :)
    Not only that, but you can run more timing all across the board with the ECM running as much as it can before it starts to produce detonation, then backing it off.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I say there isn't a point to running EFI if you don't have a distributor controlled by the ECM as well. ECM can only do so much with fuel.
