Computer geeks/gurus/wanna-be's...
Discussion in 'The Lounge' started by jarheadk5, Feb 1, 2007.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Is there any reason why I should stop considering building my own case for my next computer?
    I just don't see the need to buy a nice-looking case when it's just gonna be "hidden" in a cabinet in my desk. As I'm seeing it, if I get a PSU, some aluminum sheet and angle, and some hardware, I can fab my own drive bay frame(s), mobo mount, and airflow controls. I really don't care what it looks like, as it'll be behind a solid door in my desk, and therefore out-of-sight. Expandability would be great with this - within the size limits of the desk cabinet, I can make this case even bigger than a full-size tower.
    Input and suggestions are appreciated.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think that cases are too cheap to even consider trying to make one. Lining up the slots and screws properly for the PCI cards would be a bit of a pain. You also have to consider proper cooling and venting so you don't smoke a CPU or graphics card. If you don't want anything fancy you can find a cheap case for $50 or less.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Man, that's alot of work. Lots of precise measuring and drilling required to mount all that stuff. Then you have airflow concerns...seems like a lot of time spent for something that's pretty cheap to buy.
    You can get cheap cases for like $15.
    $50 buys you a pretty decent quiet one with lots of room for expandability, rubber mounted drives etc...,
    $100+ gets into the bling bling stuff.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    My brother got his "new" case for free. We spray painted it,and added some cooling fan's. Turned out pretty good.
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Make sure there is a good air supply behind that closed door, or your computer will frequently overheat...
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    yeah make sure there is theses guys behind it [​IMG]
