Computer Gurus...im building one...
Discussion in 'The Lounge' started by TXsizeK5, Jan 16, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    a computer, that is.
    Anyway, I built one a while back, but kinda forgot what i was doing or how i did it... my friend will help with assembly, and thats not too hard. But once you have everything, can you give me general and basics of what you have to do with installing software, like windows, and anything else, such as drivers, etc? /forums/images/graemlins/confused.gif Thanks
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Sure, what version of Winders are you puting in? What parts did you get...huh...huh...the specs! Big hard drive?Fat 32?fat16? /forums/images/graemlins/laugh.gif
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Some of this is like info you may have, and yet not really complete enough info to do anything with... If I had more time I'd write more!
    1. Boot to a floppy or CD
    2. Partition/format the hard drive
    3. Copy the OS files from the cd to the hard drive.
    4. Run the OS setup from the hard drive copy
    5. Find whatever drivers the OS can't find on it's own, then install them, but have a network driver if you plan to download them from that machine. I.E., don't start the job thinking you'll just download them from the internet once the system is built, because if the system doesn't recognize your modem or net card, you ain't gettin' nowhere, fast.
    6. If it's XP, activate the piece of manure only AFTER you've added or rearranged all your hardware.
    You'll need syntaxes and commands to do all that stuff, but if you need them, I can type them later, or some of our other computer savvy members can help out.
    Good luck!
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Yep.. give us more details and we'll have you up and going in no time.
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    well, havent done it yet... but I am palnning to run windows XP. Either Pent 4 or Athlon, not sure yet.. probably 512 or 1024 mb of memory (overkill? lol) and geforce4 card, justlike a 60gb harddrive, what other info do you need?
    Does it cost more or less to build your own? I was thinking less, but i might be mistaken!
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    BTw, where did you learn all this great stuff about computers?
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If you run XP.. Just set the bios to boot from your CD-ROM. It will do the rest.. It is setup to boot from it.. It will also have most if not all your drivers.. They made this one really easy...I built my P4 about a year ago.. And started with XP.. I think it is the best opsyst. yet. I have probably had three lockups in a year. And just went to dual monitors..It is great..
  8. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    How exactly does dual monitors work? My gf was talking about it, her professor was saying its better for programming, what exactly does it do? Thakns
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I'd go with an Athlon cpu for home. I'm using either an Athlon or a Duron right now (home, 2 years old so I forget which it is), and it performs just as good as my laptop Pentium4 1.13Ghz. I've always liked AMD for thier underdog status, but their chips are not bad at all. I think they just have a terrible marketing history, so they're not as "cool" as Intel chips to some people... I'm cool with either, but I like Athlon's while the wind is blowing this way...
    Get as much ram as the mother board and your wallet will support. Older os's like win9x may hiccup a little if you use more than 768Mb, but xp should love the more ram.
    60Gb should be fine! For better performance, get a higher spindle speed (7200 rpm).
    Video card technology I'm not as up on, but I guess that sounds good! /forums/images/graemlins/shocked.gif
    I've found with the state of big manufacturers pricing in recent years, buying is more cost effective than building, primarily from Dell or Gateway. Building a system can work out to be the same price-wise, though, but because of the balance, may be just for your personal pleasure.
    I started goofing around with computers a couple years ago, just snowballed from there. Computers are cool!
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You just have 2 monitors and 2 video cards.. You drag and drop programs between the 2. The mouse goes back and forth between them.. It is sweet.. I guess it was kinda buggy in windows 98.. But it took me 15 minutes to set up in XP. The only problem I had was I had the monitors on the wrong side of each other.. Meaning when you moved the mouse to the right it jumped on to the right side of the other screen.. Just moved them around and it is great..
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    if you get it going and have some problems check out computing.net
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    ITS REALLY HARD to go back to a single monitor after having two though!
    Yep.. It sucks when I go into work and have to use one.. . I am thinking about three.. I have 2 more PCI slots... My wife will kill me thou....
  14. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yea but those are only 32 meg cards.. I like 64 meg for the games..LOL Both mine in there now are 64 megs.. One AGP X4 and one is a pci...
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah, I play double helix on mine and its OK. The NEWNEW Matrox card is a 128MB or 256MB DDR TRIPLE head (and its supposed to pull games across all three screens).
    Parhelia
    [​IMG] /forums/images/graemlins/thumb.gif
  17. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yea those cards have to have a power supply hooked up to them.. I bet they run over $500.00
