Computer gurus...
Discussion in 'The Lounge' started by jarheadk5, Sep 8, 2004.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Finally got my router set up - it's a Linksys Network Everywhere NR041 fed by my cable modem. Got a couple questions:
    1. I have ZoneAlarm running on my laptop from the pre-router days. Do I still need to run it with the router?
    2. Are there any settings I should change from the factory defaults? Stuff like DHCP and NAT, which I know nothing about...
    3. Now that the router is in, my WinMX doesn't work anymore. I have it configured for a secondary connection. Do I need to assign an open port in WinMX and in the router just for WinMX to use, or is there another way to get it working again?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    1. No. The only time you might want to run a software firewall along with a hardware firewall would be if you wanted to filter OUTGOING traffic. For example, some pirated software tries to call home to verify if a CD key if legit or not. WIth a software firewall, you can stop that. Please note I am giving an example and not condoing piracy.
    2. I didn't have to change any of my defaults. My routewr is wireless so I had to change some of the deafults for the wireless part, but not anything else.
    3. Can't help with that one as I don't use winmx. I've never had a problem running any programs with the router. AFAIK the programs don't even know they are connecting through a router.
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    3. I've never had trouble with my Winmx working with the router, I've always had to use a secondary port but you said yours is already like that. Perhaps try to detect the connection again?
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    You should be able to leave it at defaults, but as a personal preferene, I would change the settings on the router (match them on your machine) to enable wireless encryption (wep). If not, I'd recommend leaving the software firewall installed.
    I really recommend enabling encryption though. I've been in situations where I need a high speed connection quick while in the car, and have driven around until I found an unsecured (unencrypted) network and used their internet connection. If I were malicious minded, it would be just as easy to begin attacking any computer they have connected, or using thier internet connection to commit any crimes that I would not want traced back to my IP.
    Between you and I, there are a couple networks in my neighborhood I was able to start picking up when I got my vaio with the better wireless antenna...I was realllly tempted to send eerie pages to their printers (which I found right away) like "This paper is too cheap, you're totally messing up my rollers."
    I have no idea on the winmx thing...
  5. jarheadk5
    Mar 6, 2000
    4,389
    PA
    To clarify - it's a hardwired router. I'm not ready for the wireless leap just yet...
    As for WinMX, I guess I'll just mess with it. I did get it to connect, but nothing worked. Searched for common stuff that normally gets hundreds of results (common band names, then finally porn /forums/images/graemlins/rolleyes.gif) and got NO results at all. I don't get it... /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
