computer help needed
Discussion in 'The Lounge' started by m j, Jan 13, 2002.
  1. m j
    m j 1/2 ton status
    Dec 28, 2001
    i guess I was deleteing stuff with wild abandon and have screwed up my system again.
    when I try and get pics from my digi camera I get this lovely little gemSTIMON caused an invalid page fault in
    module KERNEL32.DLL at 0167:bff7b9a6.
    EAX=00000000 CS=0167 EIP=bff7b9a6 EFLGS=00000246
    EBX=018f01ad SS=016f ESP=013cfb5c EBP=00520d94
    ECX=018f0078 DS=016f ESI=018f01ad FS=2abf
    EDX=020356ec ES=016f EDI=00000000 GS=0000
    Bytes at CS:EIP:
    ff 76 04 e8 13 89 ff ff 5e c2 04 00 56 8b 74 24
    Stack dump:
    018f0078 02024a39 018f01ad 00000000 018f0078 0202471d 018f0078 00000000
    00000000 018f0078 777f1660 018f0078 013cfbbc 0203430e 00000000 02027c81
    I tried reinstalling camera software and reinstalling windows a few times, didnt help.
    no idea what to do next.
    anyway I have a few cool photos of a home done K5 on tracks but they wont jump into the 'puter.
    formerly 77chev
    still a jerk though
  2. 2Dogs
    May 4, 2001
    Could be the camera software also....
    If everything on the 'puter works good after a clean install it probably is the cam....
    Do you have another of the camera media? Did you try that stick/floppy?
    I think you need to change the pinion angle to.. er, wait, wrong hardware..... HA
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    Los Estados Unitos
    Also, make sure you've uninstalled stuff before re-installing, all the way down to renaming the program folder (rename instead of delete so you can roll back some steps if needed). Sometimes you can re-install a million times, and there's still a bad dll in the software's working directory that gives the program misinformation and leads to a crash...
    Did you actually do a clean windows install or a re-install over an existing setup? Reinstalling only helps sometimes...
    I would first run Windows Update, and select all critical's, and any driver's. Then uninstall and reinstall the software. Then if you still have problems, format and reinstall everything on the box. Sounds like you were looking to do some winter cleaning anyway...!
    Oh yeah, and you might also want to try the camera on a different computer to make sure it is or isn't functioning correctly!
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Prior signature burnt. This one on temporarily.
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    Clearfield Ut.
    I know who I'm comeing to with computer problems!
    The above sounds like a problem I'm dealing with. The computer caught a bug, erased "links" (?), so it doesn't know how to find the programs. (?) - Anyway, it won't run my G.M. STC tranning C.D.s (the real resson I got a comp in the first place). I've un0installed and reinstalled the GM STC program serval times, with no help.
    Don't reply if I'm swipeing the thread, I'll make my own post if I can't figure it out.
    But It kinda sounds like the same problem, just a different sorce.
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by Twiztid on 01/13/02 09:09 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;
