Computer help
Discussion in 'The Lounge' started by ktedesco, Mar 18, 2005.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    Anyone know how I can completely erase my hard drive so I can start my computer over from scatch. It is all screwed up with viruses and hijacking stuff. I have saved all my important stuff on CDs. The problem is I don't have a boot disk or anything like that so I can reload Windows and all the necessary start up stuff. This thing is really acting up now. I have to ctrl+alt+del and open up task manager so I can end process on about 20 things before I can use the computer.:mad:
  2. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    What you are trying to do is Fdisk the drive. This command repartitions the drive. This is one of the best ways to start fresh. The good new is the Windows install give you options to delete/create partitions. This is the same as using the DOS command but much easier. Other than running a low level format this is the best way to eraser a hard drive. What version of Windows OS are you going to be using? Make sure to back up any thing important and have copies of any drives you may need. If you are using XP it has most drives preloaded. Once you have installed the new OS go to Windows update and load all available updates. Install a good anti-virus as soon as possible too. Good luck.
    Try downloading, installing, updating and running Ad-aware SE and Sptbot search & destory first.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You'll need some sort of boot disk to run fdisk and format the drive, look around the internet
  4. ktedesco
    Mar 21, 2004
    365
    I use Windows XP Home Edition. Since I don't have the disk do I need to buy Windows XP in order to reinstall it.
    Do you know of any websites that could walk me through the Fdisk procedure?
    I see you live in Alpharetta, my dad lives there. Small world.:grin:
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I sent you a pm.
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    i dunno if you made any progress with this, but if your pc is retail, you can check to see if it came with a "restore disk". You can usually boot to those and make like 3 or 4 choices to re-install your system.
    I'm guessing by you saying you dont have a disk that you don't have a restore set...
    Before you blow out your system, make sure you pick up an install cd and legit key for windoze... If you get a bootable XP install cd, you can format the partition as one of your choices during the setup procedure, I think somebody said that already.
    If you don't have a key or a special version of windows, you should probably wait til you get that to do anything....
  7. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I agree. Make sure you have install disk or there is a hidden partition to reinstall before you do anything.
