Computer question for the gurus...........
Discussion in 'The Lounge' started by BurbinOR, Apr 27, 2004.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Why is it when I open another IE window from within a window (hyperlink) the new window ALWAYS opens up minimized (2" square box). Running Win XP pro on a new Dell laptop..........thanks.
    /forums/images/graemlins/whistling.gif
  2. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Because that is what you have it set up to be... What you want to do is stretch it in both directions before you close it next time and that is the size that it wioll open up at next time you open a link... /forums/images/graemlins/peace.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    mine just started doing the same thing and nothing i do will fix it /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    nope still doing it /forums/images/graemlins/angryfire.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Open a window.
    Manually drag the window to the size of the screen (not the maximize button).
    Close window.
    Open another window and it should open to the full size.
    If that doesn't work, then I have no idea and I'm talking out of my ass.
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Open a window.
    Close window.
    That's what I do when my sister messes with it /forums/images/graemlins/mad.gif
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Then switch to firefox.......
    Hahahahaha, anyway, yeah IE should retain the form of the last window closed
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    it wont retain a size if you simply "maximized" it.
    it has to be hand streched.
    If it still doesnt, your registery keeps the exact pixle width and height.
  9. BurbinOR
    5,829
    Oregon
    So far the stretching method is working...........thanks! /forums/images/graemlins/thumb.gif
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    not for me /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  11. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Works for me on XP and 2000
    Try this, right click your Blue E (IE icon on the task bar at the bottom... not the one on you desktop), go to properties, in the RUN dropdown box select Maximize. Open IE, its should be maximized, now restart the computer /forums/images/graemlins/waytogo.gif
  12. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Also check your home page from the control panel. Far fetched, but you might have some kind of spyware opening a hidden IE window, then respawning a visible one with your old home page in specific dimensions each time you fire off IE.
    Try also killing each instance of the Iexplore.exe process, then go to start->run, type http://www.google.com and hit OK, resize that IE window and close it. Then go back to start->run and open google that way again, and see if the size is retained properly. If so, your home page is probably resizing it. If not, something probably has a hook in explorer that's causing it.
