Computer related, temp controlled fan on/off setup
Discussion in 'The Lounge' started by jjlaughner, Nov 7, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK, I just toasted a power supply. I have several fans in my case but I have this 92mm Tornado fan at pushes like 118CFM, I want to make it a backup, set it for 60*C and have it kick on to pull in alot of cool air. I know some front controllers do this but I'm out of of front bays, need something internal... set it and forget it /forums/images/graemlins/thumb.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    OH man a Tornado. Those things are so loud. Ill call my friend who know a lot more than me and see what he says. /forums/images/graemlins/thumb.gif
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Cool, yeah its loud, thats the only reason its not inthere now. I have 2 92mm vantec stealths pulling in, one 92mm steath going out, one 80mm blue LED silent going out, two 60mm pulling in over the harddrive, and the new power supply has two 80mm fans (one pulling in the bottom and one out the back). So I figured if that was ever to get hot i want to know! A tornado fan kicking on would definalty get your attention! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    What kind of case is it? Justr your run of the mill case? Do you have some front fans already? If not take the front of the case off and look for some holes in a square pattern that will fit an 80 mm fan. They now come with screws that you screw the fan into the case. You could put one of them in there.
