computer Tech's (windows problem)
Discussion in 'The Lounge' started by BowtieBlazer, Nov 6, 2003.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    computer Tech\'s (windows problem)
    When I reboot my computer it gives me the option to start WIN200 or Windows 98....with 15 or 20 seconds it automatically selects the default.... I just used this 98 box to install 2000 on a loose hard drive i have, so 2000 isn't even on this box, I need to remove win2000 as an option at boot up...any directions to the files I need to delete would be very helpful as when i reset my computer if I'm not paying attention it tries to boot 2000 and then freezes up as it doesn't exist /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Re: computer Tech\'s (windows problem)
    Right click My computer... Properties... Click the Advanced Tab... Then the Startup and Recovery Button... Then tell it default startup is 98 with a 0 sec display
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    I have those options on my 2000 system but the problem is on my 98 system and its not quite the same
    98 has when you click properties of my computer i see tabs (general, device manager, hardware profiles, and performance)
    ideas? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    so which do you want to boot......2k or 98?
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Just click around on those tabs, you should find something.
    The reason why its showing up is 2000 has itself listed in the boot sector... I dont know if there is a way to change/edit it manually? /forums/images/graemlins/thinking.gif
  6. BowtieBlazer
    Jul 15, 2001
    2,462
    Boot 98
    I did click around and found some things, but nothign related to the boot selection
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I didn't think win98 supported multiple booting. /forums/images/graemlins/thinking.gif
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    98B?? /forums/images/graemlins/thinking.gif
    dunno its a rather strange problem, and i'm good and figuring most of this out, just stuped, I think its a left over instal file and I'm gonna have to go through some boot file to remove
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Edit the file boot.ini in the root of your C: drive. That's where NT/Win2K get their boot list info from. /forums/images/graemlins/cool.gif Once you're in there, it's somewhat obvious how to set the default boot OS. /forums/images/graemlins/thumb.gif
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Since he put 2000 on it, it has the 2000 Boot.ini file now
    Might try replacing that with a win98 boot file, if it doesn't work say hello to the reinstall disk! /forums/images/graemlins/ignore.gif
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Here's another way to fix it (without having to manually edit the boot.ini file): Boot into Win2K then click on Start -> Control Panel -> System. Click on the "Advanced" tab and select "Startup and Recovery". Select the default startup OS from the drop down list at the top of the window. /forums/images/graemlins/thumb.gif
  14. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Do you have a Win 98 boot disk? 98 CD? You have to overwrite the some stuff, which should not be done by amatuers!!
    If you want further info PM me and I will tell you how to do it.
  15. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    There're a couple ways to fix this. I would highly recommend editing the boot.ini and forgetting it forever... That's the simplist way to do it without possibly ending up needing support that isn't readily available.
    Boot.ini is a system file, by default hidden and marked read-only.
    You will have to enable viewing of hidden and system files.
    Then, locate the boot.ini file in the root of C: (basically, open my computer, open c: drive),
    right click it and get to properties,
    then uncheck the read-only attribute, hit ok.
    Then double click to open, or open notepad and open the file manually through file->open (don't use word or wordpad, use notepad).
    If your boot.ini looks similar in syntax to this:
    [boot loader]
    timeout=3
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /sos
    Change the "default=" option to be C:\ (or whatever the exact characters are before the "=Windows 98" line), and change the timeout to 1.
    Another option is to re-"sys" the c: drive when booted from a win98 boot disk, which is simple to do, but can become complicated and result in a partial boot system that requires a manual "win" command to start windows (which can be automated, but still more complex than just editing the boot.ini).
    The absolute best way to fix it is to install windows 2000 and forget win98 exists... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  16. BowtieBlazer
    Jul 15, 2001
    2,462
    Wish i could but this is another computer in the house, my roomates, i crashed my 98 so logically upgraded to 2000, I used his working HD to slave my HD to and install 200 to mine and reinstalled it to my comp.....sounds complicated? well its his 98 he has no intrest in upgrading to 2000 so I need to fix his junk....I'll try the boot file....
  17. BowtieBlazer
    Jul 15, 2001
    2,462
    This is how my new file looks, this should work correct?
    [boot loader]
    timeout=1
    default=C:\
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows 98" /fastdetect /sos
  18. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Not quite, the path isn't necessary for the windows 98 line, that's sort of just waht it will display, you need to leave the C:\ line that originally referred to win98, and change only the "default" line. It hould work anyway with what you have, but I guess you know by now...
    Can't type much, wireless keyboard gon south...
  19. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    MAke sure you make a backup of your boot.ini and also have startup disk so you can overwrite your modified boot.ini with your backup in case you have a problem.
    Having said that, win98 sucks and win2000 is much better. Why not just install 2000 and delete 98?
