Computer?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, May 20, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I took my glove box off to repair it, and saw this computer lookin thing[​IMG](see attachment). Is it a computer? What does it do? What happens if I disconnect it? thanks for any help, I have 84 K5 w/a 305 engine.
    <font color=green>Money</font color=green>--&gt;Blazer
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Oh my God! That's a transmitter. It transmits every conversation you're having to the FBI. It also transmits your exact location so they know where to find you!!
    [​IMG]Just kidding[​IMG]
    Yes, that's the computer, if you disconnect it your car will not start, and all the settings will be reset. The computer is also reset everytime you disconnect your battery.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  3. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    Nope!!!!!!!...That's the flux capacitor that powers up your dithereum crystals...it makes time travel possible!!! Dont disconnect it!!!!!!no really it must be for something or it would'nt be there......hehe...sorry had to do it.....~Clint~...77 blazer
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I believe that module contains, the intermittant wiper circuit and cruise control circuitry.....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  5. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Unplug it and you Will be walking!~!!!!!
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
  6. Grim-Reaper
    7,385
    Atlanta
    Its for the Distributor. You have a knock sensor distributor. If you follow the wires they go through the fire wall between the ac box and the distributor and plug into the pig tail on the distributor. On the passengerside of the engine will be the sensor I belive the wire leading to it is blue.
    Diging it in the dirt with my K5's
    Grim-Reaper
  7. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    In 84 the vehicles were not that computer controlled. I'd bet money that you can run the truck with out it. As far as unplugging it, if it is running fine and working properly, leave it alone.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  8. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Yea they were as far as the distributor was concerned they had no vacum or mechanical advance just the lettel box and a knok senser.
  9. That would be your Electronic Control Module (ECM)An 84 might not have the full blown computer system, but that is back when they were trying to figure out how to moniter everything with EGR, oxygen, knock, speed and a ton of other sensors. Mainly used for the ignition, emissions and diagnostics functions. Some of those had the Electronic Spark Control (ESC) and others had Electronic Spark Timing (EST).
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  10. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    That's the ECM, it's kinda important with the distributor you have. I had no idea that there was one there and I about went nuts trying to find out why I had no spark at all.... Grrrrrrrrrr. Ended up finding one at a junkyard for cheap and all is well now.
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    My cruise control no longer works. Can this "computer" be the problem? If so, where can I get a new one, how much $$$ are they, and is it hard to install?
