computer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rooster53, Nov 20, 2001.
  1. Rooster53
    Rooster53 Registered Member Premium Member
    May 8, 2000
    41
    CT
    I have an 88 K5 what is involved with replacing the computer
    Cost and time? Should I do it myself?
    Thanks,
    The Rooster
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    It will take about a half hour. Just remember to use a ground strap to avoid static electric charge from frying your computer. It is a simple job that you can do yourself. Just pop out the glove box, disconnect the harness, unbolt the strap that holds it in place and it's out. Install new computer.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. dyeager535
    26,982
    191
    The question is more probably, "do you need to do it at all" As long as you know why you are replacing it, thats fine, but its very common for people to replace ECM's because they think its the problem, when its not. FWIW.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
