Con-Ferr Axle Trusses
Discussion in 'The Garage' started by zcarczar, Mar 23, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Does anybody run these? i was thinkin of gettin one for my front and maybe my rear axles
    BTW: im runnin 10 bolts front and rear on an 89 k5
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    From what I've heard they are pretty much just a waste of money. Look pretty and shine up nice on a show truck, but not much function offroad. Not tough enough to stand up to anything.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't bother. It will just take away all your ground clearence. I think Steve Frisbie (Missouri Offroad) makes over the axle trusses if you really want a truss. I am not sure why you'd want to truss a 10 bolt, you could spend the money on a stronger rearend. Trussing an axle is usually for jumping it, or hitting it on things real hard, and even with a truss a 10 bolt won't last long under conditions like those.
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I bought a used one for my front 10b... looks good to me and I am happy with how it'll look and work when I swap in the other 10b....
  5. zcarczar
    Feb 10, 2002
    2,495
    alrighty then, i think i will save money for new axles
  6. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I run one on my 89 K5.....mainly because I don't want a D60....it was like $85 from Rocky Mountain a few years ago.....its' unobtrusive in the mud.....
  7. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    SF make a trick truss for a D60 front?
    I'll be running a ff14b out back.... and since I dont jump it off cliffs, it'll be ok... but the front prolly takes the biggest pounding so maybe a lil trussing there would be a good thing....
    J
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    He could probably make something custom for you. I don't think he produces them. From everything I've heard about his work it is top quality, so if he custom built you a truss for your D60 I bet it would be sweet.
  9. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I am still trying to find a good way to go over the top on the front axles. There are a lot of clearance issues. I have found a way to truss them under the bottom without losing clearance at the diff. Just an FYI
  10. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I dunno, maybe the only way to do it is to have it custom done... see it in mags all the time, basically just big gussets wedled on.
    J
  11. zcarczar
    Feb 10, 2002
    2,495
    Well the only thing i was thinking about these was because my dad says i REALLY need one for the front, so im going to get one for the front, and they are cheap and i dont really want to spend 300 bucks on something for a 10 bolt,
    But thanks for the answers
  12. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I am running conn-ferr super skids front and rear with a custom over the top truss for my 12 bolt rear (thanx Steve Frisbee!) The conn-ferr held my front 10 bolt straight for as much as 10 feet of air! I snapped (and exploded) a 10 bolt rear and snapped another 12 bolt rear that had no trusses and the front end was fine. Now with my 2 trusses on the rear axle I'm back to worrying about the front. If your truck is going to see ANY air time get trusses front and rear, they have saved my ass many a times. The ones with a skid plate are about $125 and without the skid plate about $80 each and worth every penny.
