Concrete Paint
Discussion in 'The Lounge' started by shewheeler, May 20, 2004.
  1. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    Has anyone here used this stuff? I'm going to be refurbing my laundry room soon and I can't decide what to do about the flooring. My laundry room is attached to the garage and right now has just a bare concrete floor.
    At first I thought about painting it and then thought maybe stick on linoleum tiles? Now I'm back to concrete paint. I'm guessing that the concrete would need to be pretty clean for the paint to adhere properly, but I'm worried about using any chemical that would get the concrete that clean /forums/images/graemlins/thinking.gif Also, to use the stick on linoleum, the concrete would need to be pretty clean, too, so either way I'm playing with hazardous materials /forums/images/graemlins/dunno.gif
    Thoughts? Experiences? /forums/images/graemlins/1zhelp.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The prep for most concrete paints is to "etch" the concrete. This is done by washing it with Muriatic (Hydrochloric) Acid. You can buy this stuff at any hardware store for about $2-3 a gallon. Yes it is harmful, but ventilate the area well and wear rubber gloves and you'll be fine.
    Make sure you get a concrete paint that is made for garage floors. There are some out there that are strictly for block walls and it won't stand up to walking on, etc. The stuff for garage floors is good stuff though!
    Now for the real question...what color to get. /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    5 gallons of white and 1 pint of red would match her truck very well. /forums/images/graemlins/thumb.gif
  4. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I'm thinking saftey yellow!
  5. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Oh btw if you get a paint with a lot of shine, you might want to think about adding some non skid additive, because if you don't, when that floor gets wet, you'll be sliding all over the place /forums/images/graemlins/yikes.gif Good luck
    nate /forums/images/graemlins/k5.gif
  6. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    Thanks for the tips! I guess maybe I'll try it. It's not too big of an area, so if I screw up, it won't be that tragic /forums/images/graemlins/whistling.gif
    About how long does it take to cure completely?? A couple of days?
    I think the color will be grey or maybe black -- as much as I like pink, I don't think I want it on my laundry room floor /forums/images/graemlins/tongue.gif
  7. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Nuthin' like day-glo high-vis colors to say "I'm a RIDNICK and I'm prowwwwd!" /forums/images/graemlins/histerical.gif
    I've considered doing my [​IMG] up in high-vis orange ... or camo (though that's been done)...
    -- A
    -- A
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    just acid wash it ,we did our concrete counter tops that way, looks cool.... /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
  9. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    Acid wash the plain concrete? How do you do that? I'm intrigued /forums/images/graemlins/thinking.gif
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    Go to a concrete place and buy some acid iut comes in different colors , we went with black/brown and you soak a rag with it and dab it on so it kinda looks like marble....
  11. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    Sounds better/easier than trying to paint it... do you have to "etch" it first, too?
  12. chevyfumes
    Feb 24, 2000
    38,584
    266
    heres a site I found and there seems to be alot of info just type acid wash concxrete into a search engine... /forums/images/graemlins/thumb.gif web page
  13. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    Thanks mang! /forums/images/graemlins/waytogo.gif
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i used to work at a painting place and we did epoxy flooring. all we did was shot blast the floor and sweep it up good and then mop it once keeping the water clean, no soap. never had a problem with it pulling up. we shot blasted it because it was very easy to clean up (magnet) and it help up better, imsure you could sand blast it also.
    i recoment epoxy, its takes a beating and still looks great. its a little more $$$ but i think its worth it. /forums/images/graemlins/waytogo.gif
