Condenstation in engine?
Discussion in 'The Garage' started by big dan, Feb 17, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I just got home and checked my engine before starting it and it had a little bit of the grey gunk that happens when water gets mixed with the oil. I checked it out and i can find it on the pvc valve and breather tube but not in the crankcase or anywhere else. could condesation after sitting for a week cause this to happen or do i have a bad pvc valve? ive been having problems with the pvc valve also, it rattles like its suppose to and has plenty of vaccum but i dont think it is working right, how can i tell if it is? thanks
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    If it rattles, it works. Couldn't tell ya about the condensation though.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    How long do you let it sit in between runs?
  4. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    It usually sits about a week while im at school. gas mileage is too bad to drive back and forth so it usually only gets drove on the weekend. thanks.
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Condensation can build up if the engine is not run at operating temperature for a while. It will also build up if the PCV valve isn't working correctly. I change my PCV valve everytime I change my air filter, they don't cost too much.
  6. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    i have the same problem with my quad but its from mud and deep water so i put a new o ring on the cap for fillin it with oil scine its close to the bottom and it seems to help now lol i gotta do is replace the rings so i can keep oil in it lol
    Jason
    "keep on truckin"
