cone washer questions for high steer arms
Discussion in 'The Garage' started by k5-newbie, Mar 22, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    A friend is machining me some high steer arms for my D60 and said i was gonna need some cone washers for them. Anyone know where I can order these and maybe a part number...or did I misunderstand him? I am high steer ignorant so all help is greatly appreciated.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I havent figured out where to get them either....
    basically take a round ball and cut it in half... drill through it... and that is what it is... so you can use a regular bolt vs stud
    or you could use the stud with the correct nut... however the studs arent cheap.. like $40....for the set of 4
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Aren't they used on the stock steering arm?
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    If you need any d60 steering parts shoot me a pm of what you need and I'll see what i can scrounge up.
  5. Habez
    Habez Registered Member
    Mar 27, 2003
    45
    Houghton/Frankenmuth, MI
    I found mine at a place around my house called Michigan Truck Spring. They mainly work with larger semi's and commercial type trucks.They even had the size I needed in stock. I would check if there is anywhere around you like that.
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    cone washers suck. Use tapered locking nuts instead.
    j
  7. diesel4me
    Jul 24, 2003
    17,558
    939
    Massachussetts
    yup!
    I took off and put on steering arms for lift kits on my trucks and butchered the studs and nut and the cone washers bad,and sometimes the studs came out instead of the nuts unscrewing! --Had to use the torch on more than one--I used grade 8 bolts and grade 8 flatwashers instead of studs and cone washers,,a local "Tire Shack" store that installs lift kits said thats all they ever did and had no comebacks,so thats what I did,and it hasn't loosenned up,10 years later--its welded on by the rust alone now! Looks like iron ore...:thinking:
    Another truck I got the nuts off the studs ok,but the cone washers got booggerred up and one vanished completely,so we were stuck again--then I remembered those studs are 9/16 fine thread,and so are lug nuts for an 8-lug truck--hmmm:thinking: --I had some extra long chrome ones in my junk drawer from another truck,I tried one--perfecto!!--zapped them down with the impact,and it was done!--and the studs cant rust if the lug nuts are acorn style like the ones I had--the tapered end is a good fit againt where the cone washers went too...GM should have used them in the first place..:crazy:
