Configuring a 3 wire O2 sensor?????
Discussion in 'The Garage' started by 89K5guy, Oct 5, 2006.
  1. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    I am currently running headers(no cats):D with a single wire O2 sensor but having a rich condition.What is the best way to wire in a 3 wire sensor where my single wire sensor is now?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Add hot and ground. Sensor wire is the same.
  3. 89K5guy
    Jul 11, 2005
    174
    Ohio
    Where is the best place to run the hot and ground out of harms way yet with ease of installation?
  4. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    It doesnt matter about the ground, but you will have to find a switched 12v source for the power. Do a search, there is a part number for a 3 wire connector from gm, but I dont know it. That would probably be easiest.
  5. 89K5guy
    Jul 11, 2005
    174
    Ohio
    Thanx for the help:D
  6. dyeager535
    26,979
    Take the time and run at least the hot from your fuse panel. Use one of the empty hot in run slots across the top with a factory locking connector.
  7. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    afs-74 i believe is the acdelco number, i just ran mine through a hole in the floor up to the fuse box, to a 12v switched spot, very easy install and fixed all my problems.
  8. 89K5guy
    Jul 11, 2005
    174
    Ohio
    I am buying new headers soon so when I install them I will use this 3 wire O2
    sensor instead of the 1 wire.Now I understand why my SES light would come on sometimes then go out.It also explains why I am running a little rich!:bow:
