Confirm Jimmy Rad Support?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JST12, Apr 10, 2001.
  1. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    I am ordering a new radiator support for my 71 Jimmy. I am looking for confirmation that I'm getting the right one. As I understand, the Chevy and GMC rad support and fenders were the same in 67-68. In 69 Chevy changed the fenders and rad support to work with the new front grill design. GMC did not change these parts. Thus, I should order the 68 style Chevy rad support to work with my 71 GMC fenders ( and tack weld the dual headlight buckets on). Anyone have conflicting info? Thanks,
    JT
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I cannot answer your question but what I would do is start calling places like ChevyDuty, LMC,Brothers,etc..... Call all of them and ask the same question! One of thease places must have someone working there that could tell you everything you will need to know! They might to sell you their parts too but hey as long as they answer the question.......
    Good luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. JST12
    Aug 29, 2000
    192
    Garland, TX
    Burt,
    Thanks. Where did you get your roll cage? Is it custom made? Looks just like what I need. What diameter is the tubing? thx
  4. kilomanjaro
    kilomanjaro 1/2 ton status
    Feb 22, 2000
    229
    Manhattan, Ks USA
    i have a good rad support from a 69-72 jimmy, i would sell you mine, that would probably save you some hassle in installing it. if you are interested email me at kilomanjaro63@hotmail.com thanks
  5. Burt4x4
    6,854
    Yes that is a custom job by a local pipe bender I found in the yellow pages. I forgot the exsact mesurements but I know its less than 2", somewere around 1 3/4" seamless tubing. The guy made cages on the side for sprintcars and other racing cars/trucks. This was in SanJose Calif.
  6. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Are you going to change the headlight assemblies as well? GMC had four headlights and Chevys had only two. Unless you make some adaptations for the headlights, I don't see how a Chevy rad support will work on a GMC.
    Just my 2 cents,
    72Blazerod
    http://72blazerod.coloradok5.com
  7. Crushergmc
    Crushergmc 1/2 ton status
    Mar 17, 2001
    181
    Oregon
    JST, You got it right. Do you have an example so you know where to tack the buckets on? Personally, I would hold out for a good used GMC.
    70 Jimmy, 454, 2wd
    56 GMC, Big Window
  8. JST12
    Aug 29, 2000
    192
    Garland, TX
    Thanks for the confirmation. I have my existing radiator support to compare positioning of the headlight buckets. My current radiator support is completely rusted away below the battery tray and is also dented where the previous owner let the truck roll into a post. I've decided to go with new so it will be perfect and it's only $179.00. Not too bad!
