confused 700r4/205 combo
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dewster, Sep 4, 2005.
  1. dewster
    dewster Registered Member
    Jul 21, 2003
    31
    corona ca >> austin,tx
    hello guys, my 208 took a crap on me trying to figure out about instaling a 205 on my 700r4. I've heard anything from you need to cut your tranny output shaft, to there is a special adapter to space the t case back. what is the downlow the easiest way. thans a lot :wink1:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The easiest is to get the spacer. If you do not then there are clearance issues with the front drive shaft u joint and the tranny pan. If you use the spacer it moves the joint on the T-case back in relation to the tranny pan and there is no issue. Also you have to take the whole tranny apart to change the shaft because it is the first thing to go into the case on assembly. Easy answer, Spacer is easier and from what I can figure from people on here is the spacer is preferred.
    Ira
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I understand that even with the spacer you still may need to cut about 1/8" off the tail shaft of the tranny, no big deal just use a die grinder.
  4. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    this is not the exact spacer for your needs but will give you a idea of what we are talking about.this is 4l80-e to 205.
  5. dewster
    Jul 21, 2003
    31
    thanks for the replies guys
    I Get It Now But Im Confused As To Which 205 Is Best For The Combination The Male Splined Unit Or The Female Splined Unit? Makes Sense With The Female But In My Research I Have Found That There Are Two Types That Are Both Female. Thanks
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    for your 27 spline 700r4 /th350 shaft count thay only offered the coupler style. the female setup was for 400/4l80-e setups.
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I had the same situation w/my 700 when I changed to a 205. It is possible to take a sawzall and cut the output shaft on the 700 off a little bit. Or, order the shorter output shaft and install it in the 700. You can also use an ordinary wood circular saw with a carbide metal cutoff blade in it to get a smoother job.
    The first time I did it I just cut off the shaft and it was a success. When the 700 failed the first time I had the shorter custom output shaft installed at that time. IIRC I paid just under $200 for the shaft.
    If I was doing it over again I think I would save the
    money and just cut it off. I used a stock, cast iron GM THM350-to-205 adaptor. This adaptor is noted for cracking due to the overhung load of the 205. I believe there are aftermarket adaptors which have a better design.
    Just my experience.
    steve
