Confusing amp advice...
Discussion in 'Audio' started by BillyBob, Mar 26, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    A buddy of mine told me to do this. Now, I know almost nothing about audio stuff, so bare with me. I have some Amp that looks like it came straight outta the ghetto. It's made by Urban. Anyway, it's a 4 channel, 200 watt amp. I don't know much more about it than that. Well, I'm only going to be hooking up my pioneer 10" subs to it. Now, he told me to wire the positive wire from the sub to the front side positive terminal on the amp, and the negative to the rear side negative terminal in order to get the optimu sound outta them, then switch the amp to 2 channels. Will this work? It sounds kinda weird to me. Also, how do I hook two seperate amps together? I may want to do this for some other speakers I may get later. It's just a thought.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
  3. Hathaway
    Hathaway 1/2 ton status
    Jan 2, 2001
    295
    Missoula Montana
    Your friend may be a tad confused... You can bridge the channels to the sub (rear channel left positive to the sub, rear channel right negative to the sub, voila, 2 channels become 1) But not the way he described it. Since its a 4channel amp, I'd say use the front channels to drive your mids and bridge the rear channels to that sub.
    The way your friend desribed it was almost as if turning the amp into a single channel, and the only 4 channel amp I know of you can bridge into 1 channel is an ESX......
    So like DBLAZER said, NO NO NO NO NO ;)
    Dan, '86 K5, 5.0L v8, NP208, TH700R4, open 10bolts front and rear, 3.43gearing, K&N filter, 31x10.50R15 Trailhandlers
  4. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
