connecting the 700r4 to NP205 the long way
Discussion in 'The Garage' started by tweaker, Jun 27, 2004.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    ok, question is how much do i trim off the tranny shaft to fit the 205 to the 700r with the spacer and th350 adapter?
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Re: 700r4 to NP205 the long way
    I sent you a PM... /forums/images/graemlins/thumb.gif
  3. tweaker
    Mar 21, 2004
    263
    ok, almost ready. got all the parts:
    1 7/8” spacer for the rear part # 7Q35A $45
    np205 to th350 advance adapters #50-5302 $270 1-800-350-2223 ext#524
    27 spline drive sleeve Chevy stock part #6273964 $60 www.ebay.com
    <font color="red"> *new* </font> 10mm X 1.5 X 3' metric all-thread $15 from local farm supply shop
    i pulled my NP241 off(what a mess) started dry fitting parts, it seems as though I will need to take a 1/4" off the end and roughly 1/8" of which is splines.
  4. tweaker
    Mar 21, 2004
    263
    just in case anyone ever reads this. you have to shorten the shaft by 1/4 to 3/8 of an inch to get the 700r4 to connect to the np205 with the adapter. i will post pics asap.
  5. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    good info. that sucks you have to shorten the shaft though. We did that conversion on my budys 85 that had the 208 and we didnt need to trim the shaft at all. /forums/images/graemlins/tongue.gif
  6. tweaker
    Mar 21, 2004
    263
    what did you use for the bolts or all-thread. namely where did you get the metric 10mm 1.5 all thread or did the 3/8 standard all-thread work and still holding.
    TIA
