connical washers for steering arm
Discussion in 'The Garage' started by nstarry, May 11, 2006.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    are there alternitives and does anyone near minnesota ( to keep shipping cost down) drill for them ? I was just going to run without them but I am starting to rethink that ! ( was trying to save MONEY:doah:) ( because I DONT have any ) I thought you didnt want the fource on the studs they are just there for the clamping fource !?!? so why would you need conical washers??
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    without the proper "preload" on the studs, they will fail EXTREMELY fast, as in suddenly you have no more steering, and cannot control a 5000 lb truck.
    Notice that the holes in the steering arm are bigger than the studs...those washers provide a method to locate the steering arm so that it wont have any play in it as you turn from left to right. I know the gap seems small, but it is enough that you will develop play in the steering, then shear the bolts off.
    they are VERY VERY important, and just happen to be a real big PITA as well
    Parts Mike has the parts: $25 is pretty cheap
    http://www.partsmikeparts.com/MountingHardwareForSingleArm.htm
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    PartsMike is really cheap for these.
  4. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    I need sombody that can drill my steering arm for the washers . cheaply I just got my tres drilled at 25.00 a whole and the wife is about to kill me
  5. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    does anyone know where I can buy one of these bits?????
  6. mechted
    Oct 19, 2003
    766
    Granbury, TX
    if your steering arm doesnt have conical seat drilled for the holes, it would probably be cheaper to buy a new/used one than to pay a shop to redrill it.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I've never been a big fan of conical washers for steering arms. Yes I know they are stock on 1/2 ton junk and toyota stuff too... but I have never had, needed or wanted those washers on my D60. Tapered nuts work just fine.
    j
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    So how is it that your steering arm does not have the tapered holes? What is it and what did it come from? I assume you're using it on a D44 right?
  9. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    I built it myself and yes it going on a dana 44
