Considering a re-gear...
Discussion in 'The Garage' started by RustBuket, Jul 5, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well I just installed a set of 33's and love them but I don't like the lack of power with 3.08's and a 305. I would like to go to 3.73s or 4.10's. Which would be cheaper? Also I need to know your oppinion if you think it'd be easier to buy a parts truck or just buy the gears? If I'm just buying the gears, how do I find out how many splines I have? I have a 10b front and 12b rear. Thanks alot. /forums/images/graemlins/1zhelp.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Swap your axles for 3/4 ton units and you'll get 4.10 gears for the cost of the axles + brakes and gear oil and a u joint.
    You'll also get a much heavier/stronger rear axle.
  3. RustBuket
    Feb 21, 2003
    1,618
    So my next question is; what about 8 lug 15" wheels? Where do I find those?
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Summit.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most tire stores can probably get them. I got mine threw Discount Tire Co. They are Unique brand 15x8".
    Harley
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Swap your axles for 3/4 ton units and you'll get 4.10 gears...
    you won't always get 4.10 gears, most likely in the 73-80 or so you will. my 3/4 ton has 3.42 and im buying a 86 k20 that has 3.73. im just saying just because its 3/4 ton doesn't mean its 4.10 gears, check it first /forums/images/graemlins/waytogo.gif
  7. RustBuket
    Feb 21, 2003
    1,618
    Alright guys, thanks! I am now searching for that elusive truck that someone wants to give away... /forums/images/graemlins/histerical.gif Yeah, right... I'll check out summit for wheels.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] My 78 3/4 ton axles are 3.73's.
  9. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I second that! Be patient and look for the 4.10s. I've seen 'em go for as little as $50 and herd of them going for as much as $500 /forums/images/graemlins/eek.gif
  10. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I have 33s, 305, and 3.73s. Get something lower. 4.10 or even 4.56.
  11. RustBuket
    Feb 21, 2003
    1,618
    Yeah I figured that the step up to 3.73's would help *that* much.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What transmission? If it is a 700R4 here is what I suggest.
    31" = 4.10
    33" = 4.56
    35" = 4.88
    37+ = 5.13
    I had 32's and 4.56's for awhile after my 3/4 ton axle swap and regear. I LOVED it. I now have 35's (plan on 37-38's) and I wish I had 5.13's.
    I did 4.56 gears with plans of 35" tires and I didn't go low enough. I didn't know better then but I do now. Don't make my mistake. Regear for whatever tire size you plan on not what you run currently.
    Harley
  13. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    <BadDog>
    <font color="red">
    Ok guys, exactly what is the point of this off-top post? Let's end this right here. Political commentary and the like belong in the Lounge, not in the Garage. Let's keep this forum focused on off-road and 4x4 issues...
    </font>
    &lt;/BadDog&gt;
  14. RustBuket
    Feb 21, 2003
    1,618
    I have a TH350 so I don't want to go *too* low because highway RPM's have to stay semi-decent. I'm thinkin 4.10 will be alright from what I've heard.
  15. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Re: Considering a re-gear... *DELETED*
    Post deleted by fad2blk99
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I know they won't always have 4.10s but they seem to be more common than anything else with 3.73s a close 2nd and I have only see one set of 3/4 tons with 3.42s in my life.
    I got my 3/4 ton axles from an '82 K20 for free before I even knew what CK5 was. They lasted me all the way until this spring when I swapped them out.
  17. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I got ripped! Mine came with 4.56 /forums/images/graemlins/angryfire.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  18. ugly_blazer
    Apr 12, 2004
    1,214
    4.10's with 33's and a th350 should be ok, especially if you want to keep your highway rpm low. If you plan to switch to 35's later you may want to consider 4.56's, that's what I run and it does ok.
  19. backcountry
    May 27, 2004
    916
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/woot.gif
  20. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I want to eventually have more gear also , run the same gears and tire size you do , with a 305 as well ( for now ) . I am only going to 4.10's and 35's eventually , so I don't have to cruise on the highway at real high rpm's ( near 3000 rpms and extended trips don't sit well with me ) . Don't forget that tires usually measure slightly smaller than what they say on the sidewall by an inch sometimes /forums/images/graemlins/k5.gif
    Gear Table
