Considering ebay for my Blazer , what do you think it's worth ?
Discussion in 'The Garage' started by alaskanbowtie, May 2, 2005.
  1. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    I'm considering selling my Blazer and maybe through Ebay . So tell me what a realistic price would be to ask for ...... specs are as follows
    78' K5 with 87' front clip and top .
    Nice interior , custom covered buckets with black and deep red cloth (rear bench is still tan factory) . Billet dask kit , Auto meter tach and oil guage , all other guages work fine .
    Billet steering wheel , and hurst shifter for transfer case . All new carpet in side last year , and door panels , body is solid , underneath has had some rust issue's with floor pans which has a piece of 18 guage sheet metal installed over them front to back , now solid . Heater works fine no a/c .
    10 bolt front & 12 bolt rear , stuffed with 4.56 gears last fall , everything in front redone , ball joints , tire rods drag link etc. , Locking Warn hubs , TH 350 trans with 20 or 30 thousand miles , heavy duty EVERYTHING , 2 stage shift kit and mild stall . Transfer case 203 rebuilt with tranny and part time kit installed . 4" E-Z ride full spring suspension , with custom lengthened front & rear shafts , Long travel suspension ( 13.5" Skyjacker shcoks ) front ford towers . End to end steering stabilizer . Crome diff covers front & rear . 36" swamper radials with about 30% tread , maybe a bit more ? on 15x10 Aluminum wheels . no frame cracks around steering box !
    Now for the good part
    Motor: 5 ,000 miles maybe 6,000 on rebuild .
    350" sbc .040 over = 358 , high volume Moroso blue printed oil pump , 6.00" steel rods , Keith Black pistons "flat top" , Moroso 7qt. Kick out pan & windage tray , center mains studded, outer Milodon bolts "All hardware ARP or Milodon TOP & Bottom . Total Seal gapless rings , file fit . Rotating assembly balanced to with in 1/4 gram internally and crank weight lessened , Block was shot peened , magged , decked to zero with total quench at .038 , DONE RIGHT ! Crane cam specs : 214'" intake & 224" exhaust @ .050 . cam degreed , Pete Jackson gear drive with billet timing cover , machined for roller bearing button , (to stop cam walk) .
    Heads are 462x castings , 67cc chambers, Manley pro flow valves , 2.05" intake & 1.60" exhasut . Ports hogged and complete 2nd stage street port done $880.00 ea. (by brownsfeild heads several years back , now AFR I believe ? ) matched to fel-pro gaskets , intake ported to match , Holley contender , Chrome moly Jumbo retainer , 7 degree locks teflon seals , crane 1.550 double valve springs , 7/16" screw in studs and guide plates , Crower Stainless roller rockers with posi locks and Crane stud girdles , Accel ignition , Platinum Split fire 2 plugs , Edelbrock 750 carb with jetting done and offroad kit , SFI chrome dampner & painted block/heads chevy orange , Flow Max Headers with Aluminum gaskets , dual 2.5" exhaust through Dynomax mufflers . This Motor with a bigger cam can spin 7,000 rpms with these heads no problem , if the new owner decides to put in a bigger cam , the heads will flow enough to support a fairly healthy cam ! in the 2.50" range . New 4 core radiator & pump when engine put in .
    Compression at 10.3.1 , "conservatively rated" around 385h.p. & 435 trq. , rings were file fit for 100 h.p. shot of Juice but I've never bought the set up . It runs well ! The body on the Blazer has some wiskey bumps but looks fairly good , it's not a show winner but is a solid 4 wheel drive , Doesn't look to bad when cleaned up . Has winch bumper on front and 2 KCs , chrome grill , chrome rear bumper and trailer hitch . Fenders have been trimmed , to allow for the flex with bigger tires and no more lift . I can send pics if anyone "seriously interested" , I live in Haines , AK , I don't drive it to much because it gets 7 mpg and you have to run premium . But mechanically I'd drive it any where , (if I could afford it) , What is it worth ? I figure if I can't get $4,000.00 for it then I won't sell it . I have almost $7000.00 in the engine alone Summit and Jegs love me .....LOL .
    So tell me what you think ? Should I do ebay , I've tried locally and know one has any money for a toy . What would you do ?
  2. CK5
    May 19, 1999
    21,622
    701
    CO
    Are you kidding me? Isn't that what ebay is for, to find out what it's worth, as it is an auction.
    Sign up for a Membership and slap it in the for sale section where it belongs, still cheaper than autotrader.com etc.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Dude your in Alaska. I believe if your gonna get rid of it, you'll have to sell it locally. $4000 sound good to me but I've never paid more than $400 for any of my fullsizes. If you put it on ebay set the reserve at 4gs and start it at a dollar. You'll find out what they're willing to pay.
    BTW Steve I'm digging the new avatar. :xmas:
  4. alaskanbowtie
    Feb 15, 2004
    112
    ALASKA
    Just curious if ebay is actually dependable
    My concern was if others have had issue's with people not paying or more trouble than it's worth , you know , past experience in the auto sells on Ebay , I mean sight unseen is some what scary to trust !!! So yeah I suppose I am series , more than anything wanted to hear , "yeah it worked great for me selling my Blazer" , or something similar . Some encouragement . :D I have paid for memberships in the past and just haven't renewed it yet this year , I still never got the stickers from the last two times ?? But thats another issue !
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Well if thats what you wanted to hear then I haven't had any dead beat bidders........yet, but maybe I've been lucky. Now that we know what your asking I'm sure someone else will chime in with their experience. :xmas:
