Console Shaking
Discussion in 'The Garage' started by 1990k5fan, Mar 26, 2007.
  1. 1990k5fan
    1990k5fan 1/2 ton status
    Jul 7, 2006
    217
    Gilroy, CA
    Well, as the title suggests, under hard acceleration, my console begins to really shake. It will make all the change in the cup holder rumble very loudly. What would cause this shake? Broken Tranny Mount? Anything else to check?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Its picking up a vibe through the floor pan. Could be anything from unbalanced tires, to drive shaft or worn out motor/trans mounts
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have serviced everything short of the body mounts , and the tranny itself in the last five years , and I still get the shake at times .
    Just an old truck :thumb:
  4. resurrected_jimmy
    May 23, 2005
    2,241
    Guess I just didn't notice so much after my console pulled loose from doing that for who knows how long ........:haha: I never put it back in. Its still sitting in the garage
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    U joints will do it. Also, on mine, I had a bad motor mount and it let the drivetrain shift enough for the tcase to hit the floor pan on the pass side. Some of Kerts motor mounts solved it.
  6. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    most likely, you have a mogwai in there and he's trying to get out and be your furry little pal. but, don't feed him after midnight or....:yikes:
    u-joints are the next most likely thing. specifically, the front join of the rear driveshaft. maybe make sure the slip yoke isn't loose.
  7. reaper450
    reaper450 Registered Member
    Jul 4, 2006
    21
    ohio
    man, mine does that but its just because the engine is too big. Wait, what am i saying, an engine is never to big. Just an idea but you could try putting some rubber washers under it to decrease some of the vibrations, that and make sure its really tightened down good.
  8. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    How about taking the change out of the cup holders or
    just turn the radio up:p:
  9. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    It seems all the questions you ask, narrow down to one answer. It`s an old truck, period. Expect these things...
  10. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I can solve this!
    1.) Remove the change from it.
    2.) Place in ash tray
    3.) Close ash tray.
    4.) Listen to loud music.
    Sounds like what most said about drive train vibs.
