Constant vacuum or Zero at idle?
Discussion in 'The Garage' started by Okiemuddog, Jun 14, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I got the timing set on my /forums/images/graemlins/k5.gif today and it is running a lot better, I have the timing set at 8 degrees BTDC, which I think is correct. My engine is out of an '81 K30. The problem I am having is that it idles about the correct RPM's with the vacuum advance unplugged from the carb. When you hook the vacuum advance back up the engine idles way up. I have checked to make sure that I have the correct port, but all the ports on my carb have vacuum at idle, I have a stock 4BBL Q-jet. Does anyone have any suggestions? Is my advance supposed to have Zero vacuum at idle or constant vacuum? If zero then where am I wrong with the advance causing the engine idle too high?
    Thanks,
    Krennen
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    the vacuum for the ignition is suppossed to be ported vacuum. it is suppossed to have 0 at idle and go up gradually as you give it gas. on a q jet i believe its in the front passenger side. check and make sure there is no vacuum at this port with it running.
  3. dyeager535
    26,979
    I believe some of the HD trucks were running un-ported vacuum well into the 80's, so that may be correct.
    Ported vac advance on a Q-jet will be on either the drivers or passengers side, but always along the front.
    You may see a little "leakage" even on the ported fittings, especially if you've got the idle screw cranked way in. more often than not though, it's the drivers side that has the ported vac for advance.
