Contant clicking noise in engine compartment?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AntAZBlaz, Apr 20, 2002.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    Hey
    I have a constant clicking noise on my engine bay near the rear. Now a friend of mine said that it was a spark that was missing. I tried unplugging the sparkplug wires and putting them back, but I still I still have the clicking sound. I don’t really notice anything other than the sound. Any ideas of what it could be or how to trouble shoot. Thanks for any help.
    Anthony
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Could be an exhaust leak at the manifold, they tend to sound metalic. Maybe distributor related, how does it idle?
  3. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I have a clicking/popping in the left middle and i am convinced it is an exhaust leak. I also had a popping in the rear of my engine compartment and i figured out after a little shock that a wire had come off my distributer. My air filter had knowcked it off.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Where exactly at the rear of the motor are you talking about? Like lower down by the exhaust or on top by the air cleaner?
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    MY INJECTORS TICK LIKE CRAZY.
  6. AntAZBlaz
    273
    Mesa AZ
    On top around the air cleaner area
  7. AntAZBlaz
    273
    Mesa AZ
    it idels fine the only problem i've ever had with it has been that it cuts out if i start it up cold and drive for a minute then stop. it cuts out on me sometimes when i have to do that it's scary sometimes when i'm trying to manuver around a busy intersection. but it has been a wile since it has done that.
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have an exhaust leak, on my engine, that is on the pass side, and makes a ticking noise.
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Fill out your profile with your make and model (the what you have stuff), you might get some model specific stuff to target. It sounds like an exhaust leak, that would be my guess anyway. Theres not a lot other than the distributor which can make that kind of noise back there.
  10. Can Can
    15,552
    136
    Is your truck carbed or injected?
  11. AntAZBlaz
    273
    Mesa AZ
    It's an 86 carb that is the stock setup
  12. Can Can
    15,552
    136
    Have you checked your cap/rotor? It almost sounds like one of the contacts inside your distributor cap has come loose and is getting smacked by the rotor every time it rotates past it.
    Does the click speed up at the same rate as RPMs?
  13. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Mine does what would that imply i thought that that was symptomatic of a exhaust leak.
  14. Can Can
    15,552
    136
    Yep, that's also a REALLY good sign of an exhaust leak on the manifold somewhere.
  15. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    I also have the same exhaust leak as described. Passenger side. It seems to get a little better after the engine warms up but never goes away fully. A classic case of thermal expansion sealing itself to some extent. Now if I could only find an inexpensive pair of coated (inside and out) headers with thick flanges to start building a nice dual exhaust from. Yeah, I know - everybody wants that.
  16. AntAZBlaz
    273
    Mesa AZ
    thanks for all the info. is it a big deal how or what am i losing by having such a leak?
    anthony
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just tighten up your manifolds when they're cold. It'll probably quit. Otherwise, it could be the donut gasket at the bottom of the manifolds which is more involved to replace. It really won't cause any problems if you let it leak, except whatever is leaking could make it into the passenger compartment somehow.
  18. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I have ~3 lazy lifters that click/tick.
    Good Luck.
    TO
  19. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I just tightened down my passenger side header and wala the noise went away. I dont think you really loose much to an exhaust leak its just really anoying.
  20. AntAZBlaz
    273
    Mesa AZ
    I’ll try tightening them down next weekend and see what happens thanks for all that info. I’ll let you know what happens.
    Anthony
